Attached works with V8 but not with V7
Using UART1 @19200 baud.
Running at VDD of 3V3
Stated baud as if opened in V8 the baud Changes to 9600.
16F15356 RX interrupt not working.
- UART Test 16F15356.fcfx
- (19.76 KiB) Downloaded 451 times
Re: 16F15356 RX interrupt not working.
I'm interested in getting this fixed.
Unfortunately, on further investigation, it does not appear to be the same issue.
With RX1 set to B0, which is correct.
Without trying all the RX remappable pins the only one I can get to work is RC7.
That is also the POR default.
With RX1 set to B0,
RX1DTPPS = 8 & RC1STA = 144Without trying all the RX remappable pins the only one I can get to work is RC7.
Unfortunately,
I now require RX interrupt to work on channel 2 as well as on channel 1.
So far had no luck.
Using V7 as helping a friend out who has only got V7.
So far had no luck.
Hi Martin,
Please can you try adding this C code to the top of main and see if this makes any difference.
Currently missing from the init code section, ports A and C should be ok.
ANSELB = 0x00;Regards Ben Rowland - MatrixTSL
Hi Ben,
Thank you,
I will try when I get home.
I will compile a table of all the C pins I can't get to work.
Thank you,
Benj wrote:Currently missing from the init code section, ports A and C should be ok.
I have tried a few of C port and none work apart from RC7medelec35 wrote:Without trying all the RX remappable pins the only one I can get to work is RC7.
Hi Ben,
I must have been doing something wrong as with your fix all is good now.
I was probably just having an off day.
The B and C ports seem fine.
Thanks again.
Thanks again.
