When I try to convert the C code block in that was posted in this post:
viewtopic.php?f=76&t=21187#p95162
My Flowcode crashes time after time.
FC crashes when converting C code to icons
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: FC crashes when converting C code to icons
Haven't managed to replicate this - do get a pop up box with error messages.
What is the C code that you are trying to convert?
What version of FC are you using.
Is the C correct?
Note that the converter doesn't handle trig functions - but the majority of formula could be directly converted to(or entered as) FC calculations.
For example x = sin(y) + cos(y) can be entered in a FC calculation box as is - and it simulates when in FC.
The C would be FCV_X = sin(FCV_Y) + cos(FCV_Y); and doesn't simulate - would it be easier just to paste your C code into FC calculations (you'll need to remove the terminating ';') than creating a C block and then converting it back?
Is the C correct?
There was a problem with the conversion sometimes crashing in the initial release of 8.1. This was fixed in the 8.1.1 hotfix that was released towards the end of last year. Please ensure that you are using the latest version. If you are still having issues then report back here.
Daniel
Daniel
