Bug on I2C lCD
ylanchec
Has thanked: 2 times
Been thanked: 2 times
Bug on I2C lCD
Post by ylanchec »
I have open an existing working project from FC7 to FC8.
But now the I2C LCD does not works.
The LCD is a DFRobot (with PCF8574) and the card is a MEGA.
(39.7 KiB) Downloaded 1475 times
I have compare the i2c dialog on both cases :
Good (on FC7) :
(114.08 KiB) Downloaded 1475 times
Bad (on FC8) :
(115.69 KiB) Downloaded 1475 times
As you cas see there is a value added each time.
Best regards
Yannick
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Re: Bug on I2C lCD
Post by Jan Lichtenbelt »
Hi ylanchec
RW should always be at 0V (or GND). It is better to remove the conenction to P1 of the microchip.
Kind regards
Jan Lichtenbelt
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
Hi Jan,
Of course i can connect RW to GND in Proteus, but on the real card i can't modify this.
The bug seems to comes from the i2c dialog, there are too many bytes in the command. (the last byte)
Best regards
Yannick
Jan Lichtenbelt
Re: Bug on I2C lCD
Dear ylanchec
Show us the flowcode and perhaps someone can help you with the software
Kind regards
Jan
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
Hi Jan,
You will find here a zip file including :
- 1 simple fc7 writing "hello" on a LCD I2C --> HEX file
- the same file renamed and opened with fc8 --> HEX file
- proteus 8.8 file with Arduino mega linked to fc7 hex --> WORKING
- proteus 8.8 file with Arduino mega linked to fc8 hex --> NOT WORKING
The problem is the i2c dialog... not good on lcd on fc8 !
Test_LCD_I2C_FC7_FC8.zip
(93.36 KiB) Downloaded 304 times
Best Regards
Yannick
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
Software FC7 and FC8
(124.84 KiB) Downloaded 1381 times
(128.83 KiB) Downloaded 1381 times
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
On proteus 8.8
(261.96 KiB) Downloaded 1381 times
(282 KiB) Downloaded 1381 times
On FC8 there is too many bytes in a dialog !
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
Good :
(6.87 KiB) Downloaded 1381 times
Bad : a 0x00 is immediatly sent after the good value !
(13.56 KiB) Downloaded 1381 times
Best regards
Yannick
Re: Bug on I2C lCD
Hi Yannick,
I've posted a new version of the v8 component to the update system now. It contains a new property to decide if the backlight is controlled via the main display communication. When set to "No" this should be identical to the v7 component.
Let us know how you get on.
Hopefully the problem is with Proteus and the v8 component would have worked fine with actual hardware. Can you confirm if you have tried on hardware or not and how you got on.
ylanchec
Re: Bug on I2C lCD
Post by ylanchec »
Hi Benj,
Thank you for your quick response.
I have tested your new update and it's ok on proteus.
I'm going to test on a real LCD at job in few days. You means that the second sent byte is a problem only on proteus ?
On a classical I2C LCD the back light is connected to P3 of 8574.
How is connected the back light on yours ?
Thank you.
Yannick
