After update to 8.2 ?
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi!
After update to Ver. 8.2 I opened a project I have made in Ver. 8.1 for continue programming, but after update, my 2D dashboard look strange, and I lost all the text??
I have tryed to restart FC several time, but nothing help. Is there somewhere I have to "refresh" something.
Br Jorgen
ADD. Same problem when I started a new project. I have an another pc with path 8.2 update, No problem.
(87.33 KiB) Downloaded 3911 times
gavin mack
Has thanked: 3 times
Been thanked: 3 times
Re: After update to 8.2 ?
Post by gavin mack »
I have same problem
gavin mack
IT's been a few days now, no response, please advise
Hopefully this forum topic will help.
viewtopic.php?f=76&t=20993&p=94107
Let us know how you get on.
If Ben's topic doesn't help, then please PM me with the programs and I will have a look. There have been some changes behind the scenes with the 2D panel and your projects will help me determine what is going on.
Steve.
Post by jgu1 »
Hi Ben and Steve!
At the moment I am in germany for job. I am back
tomorrow and I try Bens suggest and you hear from
me. Thank’s for action. :D
Br Jorgen
SHORTCIRCUIT
Has thanked: 40 times
Been thanked: 19 times
Post by SHORTCIRCUIT »
I am having the same problem. I did an update this morning and my 2D panel no longer works with LED. The Generic, single LED does not exist anymore and what is left does not simulate.
LED-TEST 16LF1825.fcfx
(8.26 KiB) Downloaded 346 times
A simple program to flash a LED at 1 second increments.
I did the suggested Local size change as Benji stated above.
Please help as I am dead in the water and cannot proceed.
Larry
Disregard this post, I did what Benji suggested in a earlier post and now all is good -- so far.
Larry
Post by jgu1 »
Hi MM!
Unfortunaly i did not help. The problem for me is not the size, But my window look strange and miss test, and look different.
I tryed to follow Ben`s advice, but it only adjust the size, not change the component.
The component still look like in my att. picture in my first post. :|
Br Jorgen
Hi Jorgen,
Please attach (or PM) your Flowcode program so I can help solve your problem.
Steve.
Post by jgu1 »
Hi Steve!
Hereby my program for a grassmover. (It work in real world :wink: )
do you think it can help? because, so, then what about all my other program and I have the same issue and even when I create a new project.
Ok I have an another laptob And there is no problem, but when I use my laptob I use in my workbench it doesn´t work ** After update**.
Br Jorgen
GrasmoverMega1.9.fcfx
(66.16 KiB) Downloaded 364 times
Hi Jorgen,
Thanks for the file. We've discovered the issue and there is a quick workaround - set the Graphics Engine to "OpenGL hardware" (this is in the "Application" tab of "Global Options").
We'll hopefully find a fix for the software mode over the next week or so, but for now the workaround above should solve your immediate problem.
Steve.
Post by jgu1 »
Hi again Steve!
Sorry, your suggest also not change anything. Look forward to hear from you.
Br Jorgen
Hi Jorgen,
That's strange. We managed to replicate the problem with your program on a few PCs here.
Did you restart Flowcode and/or your PC? Also, when you restarted Flowcode, has the setting in Global Options permanently changed to the hardware mode?
Steve.
Post by jgu1 »
Hi Steve!
After change FC want to restart. I did this, but not restart the PC. I will try again and then restart the pc. You hear in few minute. :lol:
Jorgen
Post by jgu1 »
Sorry not Steve. Restart FC and restart PC still the same. Before update, no problem.. :roll:
Br Jorgen
Hi Jorgen,
That's strange - the problem we identified here only affects the OpenGL Software mode. Perhaps the Hardware more on your PC is not available or there is another problem preventing this.
This will not be simple for us to solve, so you should either use your other PC or install the earlier version of Flowcode. We'll try to get a fix out to you next week.
Steve.
Has thanked: 182 times
Been thanked: 179 times
Hi Jorgen
I once had similar problems.
Not only with flowcode but with other graphics programs as well.
I had to remove my old graphiccard (radeon) and install a Nvidia graphics card. Only a cheap gtx1050.
FC8.2 works fine on my two computers.
Maybe you have an integrated Intel UHD Graphics 630 processor graphics where you can change and test.
Post by jgu1 »
Hi Stefan!
Many thanks for your kind and suggest. After running and install the path 8.2 I have no problems with either FC 5 6 7 and before I downloaded the path to FC8.2 there have been no problems at all. The problem came after installing FC8.2 so and now it´s only in FC8.2. I have also no problem´s with other kind of my software.
I don't think it can be the hardware, in my opinion there must be something about FC8 8.2
Honestly, this is very strange, for the other PC I have no problems with FC8.2, and again it came after update, so????
Steve promised to investigate next week, hopefully he can do magic :wink:
Nice weekend-
Jorgen
Hi Jorgen,
There are a few bits of information I need from you to proceed, which you can find by using a tool such as Realtech VR's OpenGL Extensions Viewer:
http://realtech-vr.com/admin/glview
Specifically, I need to know the version of OpenGL used on the problem PC and information about its capabilities. Here's a picture of the GL Report screen:
(38.55 KiB) Downloaded 3574 times
At the top of the image, there are 2 buttons for saving the report (as text or as XML). If you can save that report and then post it here (or PM it to me) it will be a big help in solving this problem.
Steve.
Post by jgu1 »
Hi Steve!
Thank`s a lot. I am not home before wednesday afternoon, then I Will do what you suggest.
You hear. Thank`s.
Br Jorgen
Post by jgu1 »
Hi Steve!
Hereby the report.
Thank´s in advance.
OpenGlReport.txt
(2.31 KiB) Downloaded 261 times
Thanks, Jorgen.
This file should solve your problem:
https://matrixts-my.sharepoint.com/:u:/ ... Q?e=2tfRTo
You will need to rename the extension to .exe, and then replace the existing FlowcodeV8.exe file on your PC (you may want to make a copy of the current EXE first).
Please let me know if this works for you.
Steve.
Post by jgu1 »
Hi steve!
Oh my god, as I have told before, you MM guy´s and Valued C can do magic :wink: :lol:
After rename and replase, I start FC and Windows came up first time and make nonsense, next time no problem and the dashboard look normal
again, perfect. :D What was wrong ?
I know it is an old PC, but working very well.
Hopefully it had no influence on my project if I move my project from one laptob to another and opposite. Sometime I start a project on the one PC and maybe continue on another PC later?
I am really gratefull, and thank´s Steve.
Br Jorgen
Thanks, Jorgen. Glad we managed to fix it for you.
