Hi.
I wrote this program after doing various things.
The program worked well.
However, the Modbus does not work after updating to FC8.2.
I have a problem or another problem.
Thank you.
After FC 8.2 Update Modbus is Not work
- Has thanked: 18 times
- Been thanked: 16 times
- PRT2COM_Test.fcfx
- (34.12 KiB) Downloaded 207 times
- Has thanked: 45 times
- Been thanked: 63 times
Re: After FC 8.2 Update Modbus is Not work
Is it possible you can give a bit more information?
Do you have some problems with Master-Slave communication?
Previously, it worked fine on FC 8.1, but after updating it does not recognize Modbus from other SCADA programs. What information do you need? I'll let you know if I have an answer.
Thank you for your attention.
Can I ask you what programs do you use?seokgi wrote: it does not recognize Modbus from other SCADA programs.
I have changed a bit your program and tested it (with Arduino) as the Modbus Slave only.
FC8 does simulate a program and I see no errors.
- Mega2560_Slave_2.fcfx
- (19.34 KiB) Downloaded 194 times
This situation occurred after updating to FC8.2. If anyone has FC 8.1, I would like to downgrade and test it.
Could you upload the FC8.1?
Please can you try the following to see if it helps the situation at all.
Click View -> Global Options -> Application Tab -> Reset Data Files button -> Yes
Hopefully this should get things back into a working state for you as well as give you all the latest 8.2 goodies.
You are prompted with the same dialogue when starting 8.2 for the first time but it's very easy to click no without reading the dialogue message.
Let us know how you get on.
