Component: IO Expander (MCP23017) - error?
minolta
Has thanked: 7 times
Been thanked: 7 times
Post by minolta »
I build a system which is using an i2c graphical display and 6 x MCP23017 on the same i2c bus.
For each expander i build a macro. First five expanders are working fine.
When i initialized the sixth one, i got the bellow error message:
0: (499) undefined symbol:
_FC_CAL_I2C_Master_Init_7(Flowcode1.obj)
(908) exit status = 1
C:\Program Files (x86)\Microchip\xc8\v2.05\bin\xc8.exe reported error code 1
Autoclose turned off
FINISHED
I checked the component setup for each expander and there is no error.
I build a small test program, i got the same error.
Any idea is welcomed.
best regards,
Tiberiu
Flowcode1.fcfx
test program
(14.97 KiB) Downloaded 226 times
minolta
Re: Component: IO Expander (MCP23017) - error?
Post by minolta »
I solved the problem by creating my own component to control six MCP23017, via 12c bus.
But the Flowcode component still, has a problem with controlling more than 5 expanders.
And...would be nice to solve this issue.
best regards,
Tiberiu
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
minolta wrote:creating my own component to control six MCP23017...Tiberiu
Can you please say what have you changed in your component?
Was it the i2c address problem in FC8?
The problem is caused by the CAL layer, currently we only allow 6 x SPI or 6 x I2C channels.
I have now increased this limitation to 10 via the update system.
minolta
Post by minolta »
Hi Benj,
As usual very helpful.
Update done, tested and functional.
thank you,
Tiberiu
