Afternoon All,
Looking at an application that I would like 3 PWM channels my device only has two available only a cursory look on microchips part selector reviled that 4 channels tend to be on the high pin count devices. So thought of doing it in software have seen the software PWW example of a night rider LED chaser but this didn't make much sense, couldn't see how it was working.
A software PWM search - returned too many results "software" & "pwm"
Anybody got an example ?
I have toyed with the idea of a two timer approach using timer0 and timer2
Software Controlled PWM
Re: Software Controlled PWM
Hi Steve,
A single timer may be all that is required.
There is a software PWM example here that should hopefully help.
https://www.flowcode.co.uk/wiki/index.ph ... Interrupts
Let us know how you're getting on.
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Might be a few weeks before i can get back to you mega busy at work at the moment
Why do you say only 1 timer ?
was thinking on the lines of timer2 for the PWM frequency timer0 for the duty or is this OTT and heading on the lines of generating a headache ?
looking for a 0 - 240 count where 240 = 100% duty (trying to make the maths easy)
Steve001
Afternoon All
After mooching around RS for some parts had a go with their part selector found a couple of suitable devices had another go with MPAS these parts didn't appear
Have found the following devices - so will order them and have a go. 4 PWM channels too and supported by V7
PIC16F1828-I/P
https://uk.rs-online.com/web/p/microcon ... s/7154393/
PIC16F1825-E/P
https://uk.rs-online.com/web/p/microcon ... s/7434700/
PIC16F1828-I/P
PIC16F1825-E/P
