PIC16F19156
JLeith
Has thanked: 146 times
Been thanked: 26 times
PIC16F19156
Post by JLeith »
I'm using Flowcode 6 and I need a PIC16 with higher ram for a OLED display project
I selected PIC16F19156 for the task but I can't find the chip (Build - Find Target)
PIC16F19156 I/SP-ND from DigiKey
John
Re: PIC16F19156
Hi John,
We currently do not support this device, even in Flowcode 8. I could look at adding it into v8 if that would be useful.
I'm afraid that the compiler shipped with Flowcode 6 will not support this chip.
JLeith
Re: PIC16F19156
Post by JLeith »
Hi Benj
That is a sad time. I would of thought PIC16 family would cover all chips or at least have a update to Compiler.
The chips arrived this morning $16 dollars down the drain
Benj do you happen to know a 28pin chip with SRAM Byte 2048 ?
I have a SSD3106 OLED display that needs more memory other then 1024.
The PIC16F family in Flowcode 6 all work work with my Compiler ?
John
Re: PIC16F19156
Hi John,
JLeith wrote:Benj do you happen to know a 28pin chip with SRAM Byte 2048 ?
Looking at devices Flowcode 6 supports then what about 18F26K80?
It has 3.6K of SRAM which is over 1K more than PIC16F19156.
You can't program the newer devices with PICkit 2, without a resistor in series with VPP.
Maybe best to use PICkit 3/4 or mikroProg for PIC, dsPIC, PIC24, and PIC32.
It's not PIC16F but I'm using an 18F chip to drive a 5in resistive touch LCD and its works brilliantly!
JLeith
Re: PIC16F19156
Post by JLeith »
Thank you Martin.
Let me try the PIC18F26K80 and see if my program will complies to hex.
Back in a few minutes
John
JLeith
Re: PIC16F19156
Post by JLeith »
Hi Martin
I was able to select the PIC18F26K80 it didn't like my use of A4.
Has a internal OSC.
It compiled to Hex. Hurray...
Did get some cautions.
Caution: argument of 'delay_us' calls must have a value of 1 or more
Caution: Delay inaccurrate: 'delay_us', Delay overhead:0ms, Unit delay:0.00101725ms, Delay resolution:1 units
Caution: Delay inaccurrate: 'delay_ms', Delay overhead:0ms, Unit delay:1.00016ms, Delay resolution:1 units
Warning unreferenced functions removed:
Here is my OLED project. Flowcode
Team OLED July 3 .fcfx
(144.58 KiB) Downloaded 314 times
Re: PIC16F19156
JLeith wrote:Caution: Delay inaccurrate: 'delay_us', Delay overhead:0ms, Unit delay:0.00101725ms, Delay resolution:1 units
Take a look at this post
Also at this post
Glad it compiles for you that is promising.
JLeith
Re: PIC16F19156
Post by JLeith »
Morning Martin.
Thank you for the info on the "Caution". New beginnings for me in the PIC18 world.
John
Re: PIC16F19156
Hi John, not just for the 18f world but same applies to the 16f world as well.
JLeith
Re: PIC16F19156
Post by JLeith »
Hello Martin
My new PIC18F26K80 arrived and I started the design for a OLED display
I tried to load the PIC18 and it fails code 36
Check my connections all look good.
Here is a mock up of the board.
(196.12 KiB) Downloaded 2958 times
I listed the NFR905 wiring as black leads and the OLED
The error says it cant find the PIC ?
suggestions
John
JLeith
Re: PIC16F19156
Post by JLeith »
Thought maybe my PICKIT2 won't load a PIC18F26K80
I tried doing a Hex load with Pickit 2 and it could not find a PIC18F26K80
Does this mean I should purchase Pikit3
John
JLeith
Re: PIC16F19156
Post by JLeith »
I see the Pickit 3 at Microsoft is $47.95
And there is a Pickit 4 in the market for $47.95.
Not sure if I need to upgrade should I get the 4 or 3 version. seeing they are the same price ?
John
Re: PIC16F19156
Hi John,
Wow that's expensive! I remember when you could buy the PICkit 3 with a nice dev board for £18.
The PICkit 4 is likely more future proof. I have used one but nowhere near as much as I have used a PICkit 3 so it's hard for me to make a good call.
JLeith
Re: PIC16F19156
Post by JLeith »
Hello Benj
Thank you for responding to my latest wow as me.
I think I will go with the PicKit 3 seeing that appears to be the most common.
I found on for sale on Amazon Prime £17.73 or $29 cdn.
Now my next mountain to climb. It only comes with the PicKit3 interface.
No CD.
Benj do you know where I can get the Software and I recall the mess I had getting my Pickit2 settings
It took 3 weeks to find the settings when I had to get a new laptop.
(7.49 KiB) Downloaded 2933 times
Once I find the software to download I will purchase the new PicKit3 from Amazon.
Thank you
John
Re: PIC16F19156
Hi John,
Good find, that sounds like a better price!
You need MPLAB X and when installing make sure that the IPE option is ticked, this is what Flowcode uses and also allows you to program stand alone.
Flowcode details are here.
https://www.flowcode.co.uk/wiki/index.ph ... _.28NEW.29
Or go to the Flowcode wiki and search for PICkit.
JLeith
Re: PIC16F19156
Post by JLeith »
Hello Benj
Thank you so much for the help.
I have placed my order for the PicKit3
I will let you know how it goes.
John
