Push Button Array Issue
Has thanked: 187 times
Been thanked: 205 times
When using the Momentary Push Button Array component there appears to be an issue with the lowest "position".
When using the component, all switches except the lowest behave as expected. When depressed the associated "led" illuminates and extinguishes when released. With the lowest, the LED appears to latch. Subsequent presses may or may not register but pressing any other button brings status to that expected, until the lowest is pressed again.
Edit--
This seems to affect the slide switch array too and also affects the returned value if port is read.
PB_Array.fcfx
(7.06 KiB) Downloaded 222 times
Re: Push Button Array Issue
Thanks for letting us know. We have found the cause of the problem and are working on a fix.
Hopefully we can have it solved quickly for you.
The problem has hopefully now been resolved and the updates are now available via the help -> check for updates menu.
Let us know how you get on.
Hi Benj
Many thanks and although due to travel I can't test it yet, I have no doubt you guys have resolved.
