Assembly code
keejay
Flowcode v5 User
Been thanked: 15 times
Assembly code
Post by keejay »
Hi there,
I would like to set up Timer0 of a PIC18F46K22 as a counter. In order to do this, I need to set some timer0 configuration bits in order to configure the timer as a counter. I will also need to read the counted value from the timer register. I assume the only way to do this in flowcode is to use assembly code? Is there a tutorial as to how to use assembly code within a flowcode program?
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Assembly code
Post by QMESAR »
Why assembly a C function call with normal C code is perfect
here I am using a C icon and C code to use Timer1 on dsPIC as an example
Re: Assembly code
Have you seen the Timer component available under Data. It might already do what you need.
