ICSP
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
ICSP
Post by Jan Lichtenbelt »
ISCP is working fine with a 10 cm connection between the programming BL0080 board and the microchip 16F1847.
If I exchange the microchip with the 16F18857, ISCP is not working correctly. Programming shows the procedure works correctly, but in practice the program does not work. In both cases the low powering has been disabled.
What can be the reason?
Kind regards
Jan
Steve001
Has thanked: 460 times
Been thanked: 523 times
Re: ICSP
Post by Steve001 »
Hi Jan,
Don't believe this is a V8 issue
I experienced this with V6 as soon as you try to go past the supplied lead length with ICSP Programming you get all sorts of weird results and miss programming.
Have even tried twisted pairs and screen cables. Ended up sticking with the supplied lead.
There is a post bellow on microchip forums about this.
https://www.microchip.com/forums/m472339.aspx#472339
Steve001
Re: ICSP
Post by Steve001 »
Sorry Jan I misread your post -
Thought you where going past the standard length of cable supplied with the programmer
need new glasses I think .. :shock: :shock: :shock:
Re: ICSP
Hi Jan,
If Programming has been reported as successful i.e with no unable to erase messages,
then could the issue be configuration settings or a faulty chip?
Jan Lichtenbelt
Re: ICSP
Hi Martin,
I used more microchips 16F18857. That can not be the reason. The config word is shown below. I use the same config word for programming the microchip on the programming board BL0080 and by means of ICSP. It is still a puzzle for me.
Kind regards
Jan
Re: ICSP
Hi Jan,
None of you posts show what value OSCFRQ you're using within a c code block?
What value are you using?
