PWM 18F27K40
PWM 18F27K40
Clock frequency confirmed by 10Hz test as being 48MHz.
the delay is exactly 100ms,
Required PWM frequency = 10KHz
PWM properties: Measured PWM frequency = 375Hz
Re: PWM 18F27K40
Thanks for letting u sknow Martin,
Been EMC testing all morning and what with the heat I can't focus on this at the moment. I started and failed
I'll try and make this a priority to solve for you. Probably something to do with assuming 8/10 bit PWM but actually it's 16-bit.
Re: PWM 18F27K40
I can understand that, at least rain has help to cool things down?Benj wrote:what with the heat I can't focus on this at the moment
That's brilliant!Benj wrote:'ll try and make this a priority to solve for you.
Thank you Ben.
Re: PWM 18F27K40
Hi Martin,
I've looked a few times, this family seems to be breaking rules all over the place. I'll keep on with it
Re: PWM 18F27K40
Hi Ben,
Just noticed something after starting a new test Flowchart.
The PWM does not work at all until I added a timer2 interrupt!
After adding the interrupt, PWM will then run at the wrong frequency.
So it's getting the values from timer2 interrupt.
How strange.
Edit: Changed timer 2 Prescaler rate to 1 and the PWM went from 375Hz to 47.25KHz
This may help to shed some light on it?
PWM is set for timer 4
How strange.
Re: PWM 18F27K40
In addition to the above post.
PWM will only work if select PWM timer for Timer 4 (Tried with timers 2 & 6 which does not work).
The PWM will work at the correct frequency if Timer2 interrupt Prescale Rate is set to the required PWM Prescale.
Timer 2 interrupt Rollover Value is set to the required PWM period.
The timer 2 interrupt can be enabled, then disabled straight away.
PWM will still function correctly.
Note:
If timer2 Postscaler Rate is left on 1:1 then the Interrupt Frequency displayed will be the PWM frequency.
Hope this helps anyone with PIC18FXXK40 who requires PWM
Note:
Re: PWM 18F27K40
Hi Martin,
I've had another look into the problem this morning and pushed a change to the device definition files which hopefully solves the problem.
Thanks for chasing this one up.
Re: PWM 18F27K40
Hi Ben,
Sorry, still the same after updating with new fcdx file.
PWM does not work until timer2 interrupt set up as described in my above post.
Re: PWM 18F27K40
Hi Martin,
Wow thanks for getting back so fast. I beleive I have now found and fixed the problem for you.
Re: PWM 18F27K40
Hi Ben,
I'm afraid the latest version cases the following error:
You're welcome.Benj wrote:Wow thanks for getting back so fast.
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
MX_PWM_ALTTIMER: 748: (1500) invalid token in #if expression
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
Autoclose turned off
FINISHED
Re: PWM 18F27K40
Thanks Martin,
Third time's the charm (hopefully)
Re: PWM 18F27K40
Woohoo,
Excellent, sorry this was so long in getting to you and really happy this is working correctly now.
Thanks for bearing with and letting me know.
