Delete unsued variables, macros, etc not completly
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
I used an old flowcode and deleted all variables, macro's etc. and added my new flowcode. But try to compile to HEX and see the errors.
Kind regards
Jan
Sorry Test_Timer1_V2.fcfx was the wrong file. This is the correct one.
Test_temp_str_V2.fcfx
(12.66 KiB) Downloaded 564 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Delete unsued variables, macros, etc not completly
Post by mnf »
Hi Jan,
The problem is related to the GSM component.
If you call it's Initialise macro then it declares the necessary variables and compiles ok - either that or delete it (as it is not used?)
This seems to be a a slight bug - as you are not actually using any part of the GSM component? FC should compile and remove the unused code - seems part of the component is still being attempted to compile - and without the Initialise the setup is incorrect?
