Incapable de programmer un Arduino avec Flowcode v7.3.0.5
tech
Been thanked: 9 times
Post by tech »
Bonjour,
Voici mon problème je suis incapable de programmer un Arduino avec Flowcode v7.3.0.5, j'ai suivi les instruction du FAQ et toujours incapable de programmer. J'ai meme installer flowcode sur un autre PC et toujours le meme problème!? :oops:
https://www.flowcode.co.uk/faq/index.php ... hlight=AVR
Merci de votre aide!
Chris
Voici l'erreur:
Target folder: Y:\AM6G2H~Q\FYMMKF~S\AQZOIF~8
Source name: Y:\Arduino Projets\Flowcode v7 Exemples\ArduinoShieldTest\ArduinoShieldTest.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA2560
Generated by: Flowcode v7.3.0.5
Date: Monday, August 19, 2019 19:01:41
Users:
Registered to:
Licence key:
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat atmega2560 "Y:\AM6G2H~Q\FYMMKF~S\AQZOIF~8\ArduinoShieldTest.elf" "Y:\AM6G2H~Q\FYMMKF~S\AQZOIF~8\ArduinoShieldTest.c" "Y:\AM6G2H~Q\FYMMKF~S\AQZOIF~8\ArduinoShieldTest.lst"
Launching compiler...
ERROR: Can not launch process: The system cannot find the file specified.
Completed compilation, return = 255
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat reported error code 255
Has thanked: 481 times
Been thanked: 699 times
Re: Incapable de programmer un Arduino avec Flowcode v7.3.0.5
Can you try with a project stored on the local drive (C: ) ?
tech
Post by tech »
Bonjour LeighM,
Ok, je vais essayer ca!
Merci
Chris
tech
Post by tech »
Bonjour LeighM,
Malheureusement j'ai toujours la même erreur même si je sauvegarde sur mon disque (C:)
Voici l’erreur:
Target folder: C:\Users\User\Documents\FLOWCO~1\ARDUIN~1
Source name: C:\Users\User\Documents\Flowcode v7\ArduinoShieldTest\ArduinoShieldTest.fcfx
Title:
Description:
Date: Tuesday, August 27, 2019 12:57:01
Users:
Registered to:
Licence key:
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat atmega2560 "C:\Users\User\Documents\FLOWCO~1\ARDUIN~1\ArduinoShieldTest.elf" "C:\Users\User\Documents\FLOWCO~1\ARDUIN~1\ArduinoShieldTest.c" "C:\Users\User\Documents\FLOWCO~1\ARDUIN~1\ArduinoShieldTest.lst"
FINISHED
Have you checked that the compiler batch file exist at the path specified.
Also have you double checked that the short path to the directory is valid?
This is known to fix the issue.
You can check the short path by following the steps here.
viewtopic.php?f=54&t=20393&p=90210#p90210
tech
Post by tech »
Bonjour Benj,
J'ai verifier si le document avra etait bien la et oui (voir image). J'ai suivi les instructions du FAQ et la path et ca na rien resolu :oops:
Chris
Please can you confirm the short path is valid for the folder.
Details of how to do this here.
https://superuser.com/questions/348079/ ... ctory-file
tech
Post by tech »
Bonjour Benj,
Malheureusement je ne suis pas un pro du dos :( j'ai essayer de suivre les étapes mais ca ne semble pas fonctionne!
Quel qu'un pourrais m'aider a ce niveau??, j'aimerais savoir quel commande je dois entrer correctement!?
Merci de votre aide
Chris
Run cmd
Type in the following commands
cd "C:\Program Files (x86)\Flowcode 7\compilers\avr"
dir /x
see if you get ...
BATCHF~1 batchfiles
tech
Post by tech »
Bonjour LeighM,
Voici le resulta (voir image):
Que dois-je faire maitenent?
Merci
Christian
(37.6 KiB) Downloaded 4542 times
Has this always been a problem since installation?
Or has it worked OK in the past, then at some point stopped working?
tech
Post by tech »
C'est un pack AVR que j'ai fait ajouter a ma licence Flowcode v7 Pro en Mai 2019.
Une fois ma licence activer j'ai fais quel que petit programme sous Arduino MEGA 2560 et c'est a partir de la que j'ai ce problème!
Pour le reste PIC16, 18, uC32.....tout fonctionne bien!
Merci
Christian
In cmd box, type
cd \Program Files (x86)\Flowcode 7\compilers\avr\batchfiles
avra.bat
what do you get?
tech
Post by tech »
Bonjour,
Voici ce que ca me dit!
Merci
Christian
(55.67 KiB) Downloaded 4307 times
tech
Post by tech »
Bonjour LeighM,
Comment je peux résoudre mon problème maintenant?
Merci
Christian
Sorry, I have run out of ideas on this one, apart from trying a Flowcode update and patch update.
Or maybe disable any anti-virus or any other system utilities?
I will see if Ben has any further ideas.
tech
Post by tech »
Bonjour,
J'airais aimer régler ce problème rapidement :(
Merci
Christian
tech
Post by tech »
LeighM,
Y a-t-il une façon de configurer le chemin du dossier avra.bat dans flowcode?
Merci
Christian
Salut christian
D'accord, je crois toujours que le problème est un problème de chemin court. J'ai donc un plan pour essayer de le résoudre pour vous.
Veuillez suivre les étapes suivantes.
1) Désinstallez l’AVR toolchain à partir du panneau de configuration de Programmes
2) Téléchargez la chaine d'outils AVR
3) Installez la chaîne d’outils AVR en spécifiant l’emplacement d’installation en tant que C: \ FC \ AVR \, ce qui évite les problèmes de chemin court.
4) Ouvrez Flowcode et assurez-vous d’utiliser les options par défaut du compilateur.
Espérons que Flowcode compile maintenant correctement pour vous.
Hi Christian,
Right I still beleive the problem is a short path issue so I have a plan to try and solve the issue for you.
Please follow the following steps.
1) Uninstall the AVR toolchain from the Programs control panel
2) Download the AVR toolchain
3) Install the AVR toolchain specifying the installation location as C:\FC\AVR\ this ensures there can be no short path issues
4) Open Flowcode and ensure you are using the default compiler options
Hopefully Flowcode will now compile correctly for you.
tech
Post by tech »
Bonjour Benj,
Pour le télécharger le AVR toolchain avez vous un lien?
Merci
Christian
You can download it from here.
https://www.flowcode.co.uk/flowcode/download/
tech
Post by tech »
Bonjour Benj,
Ca ne fonctionne pas malheureusement :(
Merci
Christian
