Error in the SPI interface
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
I wanted to set up a SPI communication with a panel. Unfortunately I didn't succeed because the program comes to an end when the SPI interface is initialized.
- I use an Arduino Uno Board.
- Every 500ms the Arduino LED (Digital 13) is controlled.
- Before the endless loop the SPI interface is initialized.
- No further SPI activities to follow
If the SPI interface is deactivated - SPI is not initialized -, the program runs without objection. the LED flashes in the preset frequency. If I activate the SPI interface, the program gets stuck with this expression.
Can anyone help me?
Translated with www.DeepL.com/Translator
Flowcode5.fcfx
(8.29 KiB) Downloaded 315 times
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Re: Error in the SPI interface
Post by EtsDriver »
Hi!
Are you 100% sure the SPI bus is working and you are addressing right device?
On FC7 i remeber the ENC ethenet module had habit to stuck the program when trying to initialize the module, when it was not present...
Could this be same thing?
Have you tested that the display works?
Pascal_2016
" Are you 100% sure the SPI bus is working and you are addressing right device? "
-> I am sure that the SPI interface doesn't work under flowcode 8, because it works under Arduino-IDE with the same display.
" On FC7 i remeber the ENC ethenet module had habit to stuck the program when trying to initialize the module, when it was not present...
-> If this is the problem, the display should also not work under Arduino IDE.
" Have you tested that the display works? "
-> I am sure that the display will work, because with the Arduino IDE the display will work (the structure has not been changed).
Has thanked: 481 times
Been thanked: 699 times
You have the SPI properties set to CS on port C2, this should be B2
There is a note in the compiler output text about the need to set the SS pin as output or use as the CS pin
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
The Clk output of the SPI module and the LED are both connected to the B5 port.
Is that what you wanted?
Lagoda
No,
Your properties are set like this ..
Have you got CS connected on your device?
It would better to use B2 as CS
If not, then you must set B2 as an output (this is the AVR SPI SS pin)
Lagoda
Post by Lagoda »
Hi Leigh,
I'm sorry! :)
I wanted to ask from Pascal_2016 but forgot to type the username in the address bar.
Best Regards,
Lagoda
Ah, I see what you mean, sorry, my mistake on that :oops:
You were right to ask :D
