BL0032 Anometer
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
BL0032 Anometer
Post by Monie Jacobsen »
Hi everyone
Does anyone here see why the BL0032 Anemometer (Windspeed) is not working.
Do you have a suggestion for codes?
Please see attached codes:
BL0032_Anometer.fcfx
(20.47 KiB) Downloaded 627 times
Best Regard
Monie
Re: BL0032 Anometer
Hi Monie,
What anometer are you using and can you explain more about what isn't working for you?
Monie Jacobsen
Re: BL0032 Anometer
Hi Benj
With BL0032 - 16-Bit dsPIC I try to use an anemometer.
Anemometer type: https://manualzz.com/doc/9301349/anemom ... -type-i...
Example of Anemometer using IC PIC16F1937
Anemometer_PIC16F1937.fcfx
(16.93 KiB) Downloaded 604 times
Best Regard
Monie
Monie Jacobsen
Re: BL0032 Anometer
Hi Benj
Have tried a lot to be able to read a digital input with BL0032 with no luck
Do you have a suggestion?
BL0032_PulsIn.fcfx
(8.95 KiB) Downloaded 580 times
Best Regard
Monie
Monie Jacobsen
Re: BL0032 Anometer
Hi everyone
Have also tried this version.
Med still can't read a frequency
READ FREQUENCY_BL0032.fcfx
(11.51 KiB) Downloaded 642 times
Do you have a code suggestion so that it becomes possible to read a sequence?
Best Regard
Monie
