Problems selecting Simulation Pin for interrupt
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Post by CSM2711 »
hello, I have the following problem. while activating the interrupt I can select any pin for the interrupt, but for the simualtionpin I can only select RA0.
Is this a bug or do I not understand something here?
interrupt_test.fcfx
(16.44 KiB) Downloaded 200 times
Re: Problems selecting Simulation Pin for interrupt
On the embedded hardware you can specify the interrupt pin. The simulation currently cannot deal with this and is instead fixed to a single pin, in your case A0.
If you want a different pin for use with the sim then let us know and we can fix it to something else if you don't feel comfortable editing the chip definition file yourself.
