structure and bit fields in FC
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team.
I normaly like to use structure for data and Flags in C code how can I do this in FC
example in C
structure Appflags
unsigned char RX_INT :1;
unsigned char Tx_INT :1;
unsigned char ControlOn :1;
{ Flags;
I can then call or use the structure example
Flags.ControlOn = 1 ;
my question is how to declare structures in FC and how to access them
Any help pointer is appreciated
Re: structure and bit fields in FC
Hello Peter,
There currently isn't a nice way of doing this in Flowcode without resorting to using C code.
One way I have been playing with is to create a component with the variables you need and then create public macros to allow you to read and write the variables. If the macros are set to the embedded type (advanced) then there is a way to access the variable without the stack hit and extra instructions, this is how the DSP components function.
Once you have done this you then add the component to create an instance of the variables.
QMESAR
Post by QMESAR »
Hello Ben.
OK thank you for the info ,
I think I stick by just using variables for now ,
I appreciate your help :D
