PIC18F67K40 UART "SendString" problem (SOLVED)
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi Ben,
I found a bug while testing the UART Component Macro on CLICKER 2 board.
The "SendString" function does not work, it is not executed.
The "SendNumber" and "SendChar" are working perfectly.
(50.89 KiB) Downloaded 1524 times
3 milliseconds pause between UART TX bursts is it possible that another bug?
Best Regards,
Lagoda
PIC18F67K40_UART_Test.fcfx
(8.36 KiB) Downloaded 317 times
Re: PIC18F67K40 UART "SendString" problem
Hi Lagoda,
On 18F devices the extended CPU config setting can cause problems with strings, however looking at your config settings it looks like this is already set to disabled. Maybe try enabling the setting just in case it's been inverted?
What happens if you load the string constant into a string variable using a calculation icon and then send the string variable?
Looking at the code behind the functon it all seems to check out and makes the same UART calls as the SendNumber and SendChar.
Lagoda
Post by Lagoda »
Hello Ben,
I tried what you wrote.
After enabling, I get an error message from the compiler:
PIC18F67K40_UART_Test_2.c:
33: __config("__PROG_CONFIG", "pic18", 0x2, 0x7FFF);
^ (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
The situation remains the same. The string variable value does not move the UART TX output.
PIC18F67K40_UART_Test_3.fcfx
(8.89 KiB) Downloaded 288 times
What should the next step be?
Best Regards,
Lagoda
Lagoda
Post by Lagoda »
Hi Ben,
I did another test.
I wanted to copy a string type constant into a string type variable.
Then I convert the string variable to a byte vector and send the elements of the byte vector to the UART buffer.
This works great in the simulator, but don't work in the target circuit.
During debugging, I noticed that the string-type constans value was not copied to the string-type variable.
(23.64 KiB) Downloaded 1435 times
(31.26 KiB) Downloaded 1442 times
Thus, the string variable length will be 0 and no data will be added to the UART buffer.
Have you any idea?
Best Regards,
Lagoda
PIC18F67K40_UART_Test_2.fcfx
(11.14 KiB) Downloaded 315 times
Lagoda
Post by Lagoda »
Hi Ben,
I found the cause of the error: The MCU what I use comes from Device Revision Id = 0 series.
If the Device Revision Id = 3, the String operations will be executed correctly.
The solution is in this topic:
viewtopic.php?f=76&t=20479
By inserting Code C, the test program works. :D
(19.89 KiB) Downloaded 1397 times
Could you speed up the execution speed of the "SendNumber" function a bit?
If I count correctly, it performs about 13,500 instruction cycles before sending a three-digit number to UART. :shock:
Can this be reduced?
Best Regards,
Lagoda
Has thanked: 182 times
Been thanked: 179 times
Re: PIC18F67K40 UART "SendString" problem (SOLVED)
Hi Lagoda
Well, you have found the mistake.
There is also a Clicker 2 with a PIC32MZ on 200Mhz. With which software did you do the test? Looks very good.
https://www.mikroe.com/clicker-2-for-pic32mz
Lagoda
Post by Lagoda »
Hi Stefan,
For register level debugging, I use MPLAB X IDE (v5.20) with PICKIT4 debugger.
I use v1.45 from XC8 compiler because Flowcode8 also uses this by default.
I also like this board. It would be nice if the card had an external power connector. Because the battery can only be charged via USB
But perhaps such a connector is missing only for me from the Clicker2 board. :)
Lagoda
Lagoda
Post by Lagoda »
Hi Stefan,
Maybe you didn't mean MPLAB X? :) Sorry!
If you were thinking of a picture attached to the first post, it is the user interface of a TechTools DV518 Logic Analyzer.
https://www.tech-tools.com/DV518-logic-analyzer.htm
Lagoda
