PIC12F1572 Issues Programming & UART Issues
Sanjay Singh
Has thanked: 10 times
Been thanked: 3 times
Post by Sanjay Singh »
Hello all,
I'm facing programming issue & non-working UART with PIC12F1572 Device.
Issue1:
I'm getting "Failed to program device" error while programming the device using PK3 & the 1 sec Flasher code in the program works perfectly
Issue2:
UART not working
My compiler settings are as follows:
Compiler Options:
Compiler Location:
$(appdir)compilers\pic\bin\xc8.exe
Compiler Parameters:
--chip=$(chip) "$(target).c" --MSGDISABLE=359,1273,1388
Linker / Assembler Location:
$(appdir)tools\DoNothing\DoNothing.exe
(blank)
Programmer Location:
C:\Program Files (x86)\Flowcode 7\tools\PICkit3\PK3CMD.exe
Programmer Parameters:
-chip $(chip:u) "$(outdir)$(target).hex"
Any help in resolving these issues will be appreciable.
Sanjay
Test 01.fcfx
(10.14 KiB) Downloaded 434 times
Re: PIC12F1572 Issues Programming & UART Issues
The difference between the config values 1A03 and 3A03 is the low voltage programming setting which is being kept on and could explain why the UART isn't working as it consumes an I/O pin.
Anyway I would install the latest MPLABX and then use the IPE software packaged with this to program the device. It will likely have new firmware for the PICkit and hopefully will solve the problem?
Instructions for Flowcode integration here.
https://www.flowcode.co.uk/wiki/index.ph ... _.28NEW.29
Sanjay Singh
Thanks, Benj, Updated MPLAB X IPE to v5.25 & and the issue got resolved.
