2 PHASE INTERLEAVED BUCK CONTROLLER
SILVESTROS9
Has thanked: 24 times
Been thanked: 11 times
Post by SILVESTROS9 »
Hallo to all.
is there an example code, or a way to realize a 2 phase interleaved buck converter for FC8 , as in the design file ( page 8, figure 10 ) below ? It gives the MPLAB X project files, but I would like to realize that with FC8 .
TB3155-Multiphase-Interleaved-PWM-Controller-with-Diode-Emulation-DS90003155B.pdf
(688.19 KiB) Downloaded 252 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: 2 PHASE INTERLEAVED BUCK CONTROLLER
Post by QMESAR »
Hi.
I am afraid that there is no FC components that does this for you with that said, you can do all of this in FC8 by using a C call Icon's and setup
the PIC peripherals as needed .
I have done buck converters in FC 7 using this method
(1) use MPLABX Code configurator to generate you the configurations for the peripherals such as CLC and PWM modules
(2) The code are in the relative header / c files for the modules
(3) copy and paste the code into a C icon where necessary
(4) run the code as usual in FC where needed meaning the driver code such as setting the PWM duty cycle for example
Hope this helps :D
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Hi SILVESTROS9
Are you using this for a PSU aplication ? - PDF Not downloading for me
Have you seen Texas Instruments "Web Bench" PSU designer
http://www.ti.com/design-resources/desi ... gner.html#
https://webench.ti.com/power-designer/s ... -regulator
I have used this to design a couple of DCDC Convertors - you can download all the desgin infomation coil winding data BOM's etc.
It Also generates PCB Layouts (Eagle Format)
