HTTP GET syntax question (solved)
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
Example works OK (with matrix team example)
"GET /en/observation/rss/2647632 HTTP/1.1\nHost: weather-broker-cdn.api.bbci.co.uk\n\n"
I have 200 OK.
When I try to access the RPi3 Apache2 server by:
changing the address to: 192.168.1.100
changing the GET to: "GET /index3.html HTTP/1.1\n"
The WireShark program does not show the HTTP request, only TCP from my PC.
The WireShark shows only one HTTP line: from Apache2 (RPi3 server)
RPi3 Apache 2 does response:
HTTP/1.1 400 Bad Request.
What is the correct syntax for GET in FC8 for accessing:
/var/www/html/index3.htm
please?
"GET /html/index3.html HTTP/1.1\n"
P.S.
When I use the browser
http://192.168.1.100/index3.html
I got the result:
test testing
viktor_au
Re: HTTP GET syntax question
Post by viktor_au »
Found an answer:
request = "GET /index3.html HTTP/1.1\r\nHost: 192.168.1.100\r\n\r\n"
Now I can get Apache2 response: 200 OK.
But not enough room to get the text from index3.html
viktor_au
Post by viktor_au »
Solved.
Ard_HttpGet_RPi3_7.fcfx
(33.08 KiB) Downloaded 197 times
