PIC18F27K42 - UART
PIC18F27K42 - UART
Errors with UART component:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:408:1: error: (192) undefined identifier "TXSTAbits"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:408:16: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:411:1: error: (192) undefined identifier "SPBRG"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:412:1: error: (192) undefined identifier "RCSTA"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:423:1: error: (192) undefined identifier "RCSTAbits"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:423:16: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:426:16: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:429:16: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:437:15: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:437:18: error: (182) illegal conversion between types
int -> volatile union S151
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:708:1: error: (192) undefined identifier "RCSTA"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:709:1: error: (192) undefined identifier "TXSTA"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:788:1: error: (192) undefined identifier "TXREG"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:901:26: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:901:27: error: (182) illegal conversion between types
volatile union S178 -> unsigned char
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:901:27: error: (181) non-scalar types can't be converted to other types
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:949:13: error: (192) undefined identifier "RCSTAbits"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:949:27: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:952:9: error: (192) undefined identifier "RCREG"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:959:27: error: (196) struct/union required
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:962:16: advisory: (1) too many errors (21)
(908) exit status = 1
Error returned from [xc8.exe]
PIC18f27K42.fcfx
(7.79 KiB) Downloaded 232 times
Re: PIC18F27K42
Thanks for the spot Martin,
Looks like they totally re-wrote the rulebook for this one. The register setup is nothing like the other chips.
Hmm I'll have a think on it.
Re: PIC18F27K42
Hi Martin,
I've had a go at editing the code. Do you have one of the chips to hand?
If you do then please can you try this and let me know how you get on.
PIC_CAL_UART.c
(41.89 KiB) Downloaded 276 times
If all ok then I'll push to the update system.
Thanks.
Re: PIC18F27K42
Hi Ben,
the baud is set to 9600
Measured baud is 38.5K
Internal Osc speed is correct @ 48MHz as UART works in software mode.
Will Test RX after TX confirmed working.
Re: PIC18F27K42
Thanks Martin,
What about this?
PIC_CAL_UART.c
(41.89 KiB) Downloaded 285 times
Re: PIC18F27K42
You're welcome.
Baud dropped to 151 bits per sec
Re: PIC18F27K42
Aha thanks, yes I see now it's missing the usual FOSC/4 for the clock input :)
I've changed the new baud calc so it's actually using the full 16-bit range with the FOSC clock source.
PIC_CAL_UART.c
(46.15 KiB) Downloaded 299 times
Let me know how you get on.
Re: PIC18F27K42
Hi Ben,
Thank you.
RX and TX are now working perfect.
Tested at 9600 and 38400 BPS
Re: PIC18F27K42 - UART
Thanks :D
I've pushed the changes to the update system now.
Hi Ben,
Something has gone wrong with pushing the update on the system.
The file you posted compiles ok.
When compile with V6.0, The following errors occur:
M:\Flowcode Testing>"C:\Program Files (x86)\Microchip\xc8\v2.05\bin\xc8-cc.exe" -mcpu=18F27K42 "PIC18f27K42.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:471:15: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:471:18: error: (182) illegal conversion between types
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:854:26: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c:854:32: error: (207) simple type required for "=="
NOT volatile union S1161
C:\Program Files (x86)\Flowcode\Compilers\pic\batch\pic_xc8 V2.05_comp.bat reported error code 1
Thanks Martin,
I see what I did now I uploaded the wrong file! Should be fixed now.
I'll try and get onto those interrupts for you too.
Hi Ben,
Thank you
Yes UART is now working with the latest update.
Benj wrote:I'll try and get onto those interrupts for you too.
That's great thanks.
