DOUBT DSPIC33EP512MU810
RLOPES780
Been thanked: 3 times
Post by RLOPES780 »
What is the maximum clock I can with this microcontroller (internal) and how do I set it?
Thankful;
Ricardo.
Re: DOUBT DSPIC33EP512MU810
Hi Ricardo,
Fastest clock speed is 140MHz or 140000000 which produces a instruction speed of 70MIPs.
Set your configuration settings like this.
And then add this code into a C code icon at the start of your project.
//Setup configuration for 70MIPs using 7.37MHz int osc
PLLFBD = 68;// M=70
CLKDIVbits.PLLPOST = 0;// N1=2
CLKDIVbits.PLLPRE = 0;// N2=2
OSCTUN = 23;//Tune FRC oscillator from 7.37Mhz to 8.00566MHz
//Disable Watch Dog Timer
RCONbits.SWDTEN = 0;
// Clock switching to incorporate PLL
__builtin_write_OSCCONH(0x01);// Initiate Clock Switch to FRC with PLL
// Oscillator with PLL (NOSC=0b011)
__builtin_write_OSCCONL(0x01);// Start clock switching
while(OSCCONbits.COSC != 0b001);
// Wait for Clock switch to occur
while(OSCCONbits.LOCK != 1);
//USB H/W initialization for 70 MIPs
//ACLKCON3 = 0x24C1;
ACLKCON3 = 0x22C1;
ACLKDIV3 = 0x7;
// Wait for PLL to lock
ACLKCON3bits.ENAPLL = 1;
while(ACLKCON3bits.APLLCK != 1);
RLOPES780
Post by RLOPES780 »
Hello Benj;
Thanks for listening.
I changed the settings and ran the program below but it didn't work.
(OBS) I am not using any external crystal.
Thankful;
Ricardo.
Flowcode1.fcfx
(10.62 KiB) Downloaded 303 times
RLOPES780
Post by RLOPES780 »
sorry this program
Flowcode1.fcfx
(11.49 KiB) Downloaded 257 times
RLOPES780
Post by RLOPES780 »
sorry benj this program
Flowcode1.fcfx
(10.01 KiB) Downloaded 284 times
Hello Ricardo,
Could simply be the display that isn't working. I advise a 1 second LED flasher routine for a sanity check.
https://www.flowcode.co.uk/wiki/index.ph ... ED_flasher
RLOPES780
Post by RLOPES780 »
Hello benj;
I did the led test and it didn't work.
With this program I gave you was using a crystal of 20mhz and the display worked.
I removed the crystal (there is no external crystal) I changed the settings it gave me and it still does not work.
Can you still help me?
Thankful;
Ricardo
Flowcode1.fcfx
(9.97 KiB) Downloaded 289 times
