PIC32 PWM(internal) component (resolved)
chad
Has thanked: 27 times
Been thanked: 33 times
Post by chad »
I tried to add a IPWM component and I can't asign a pin to it. It also won't compile.
Target folder: C:\Users\ralph\DOCUME~1\PICFLO~1
Source name: C:\Users\ralph\Documents\Pic flow projects\PicMZ test 1.fcfx
Title:
Description:
Device: PIC32.32MZ.32MZ0512EFE064
Generated by: Flowcode v8.2.1.13
Date: Friday, November 08, 2019 21:35:13
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\bin\xc32-gcc.exe -mprocessor=32MZ0512EFE064 -O1 -o "C:\Users\ralph\DOCUME~1\PICFLO~1\PicMZ test 1.elf" "C:\Users\ralph\DOCUME~1\PICFLO~1\PicMZ test 1.c"
In file included from C:\Users\ralph\DOCUME~1\PICFLO~1\PicMZ test 1.c:90:0:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c: In function 'FC_CAL_PWM_Enable_1':
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:53:36: error: 'MX_PWM_RPOR_1' undeclared (first use in this function)
#define MX_PWM_RPOR_X CAL_APPEND(MX_PWM_RPOR_, MX_PWM_NUM)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:70:26: note: in definition of macro 'CAL_APD'
#define CAL_APD(a, b) a##b
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:53:25: note: in expansion of macro 'CAL_APPEND'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:74:3: note: in expansion of macro 'MX_PWM_RPOR_X'
MX_PWM_RPOR_X = MX_PWM_RPOC_X; //Assign PWM Channel OCx -> RPx - See FCD Defines For Info
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:53:36: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:54:36: error: 'MX_PWM_RPOC_1' undeclared (first use in this function)
#define MX_PWM_RPOC_X CAL_APPEND(MX_PWM_RPOC_, MX_PWM_NUM)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:54:25: note: in expansion of macro 'CAL_APPEND'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:74:19: note: in expansion of macro 'MX_PWM_RPOC_X'
C:\Users\ralph\DOCUME~1\PICFLO~1\PicMZ test 1.c:173:23: error: 'TRIS' undeclared (first use in this function)
#define MX_PWM_TRIS_1 TRIS
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:306:35: note: in definition of macro 'clear_bit'
#define clear_bit(var,bitno) var &= ~(1 << bitno)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:81:3: note: in expansion of macro 'FC_CAL_Bit_Low_DDR'
FC_CAL_Bit_Low_DDR (MX_PWM_PORT_X, MX_PWM_TRIS_X, MX_PWM_PIN_X); //PWM pin is an output
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:70:26: note: in expansion of macro 'MX_PWM_TRIS_1'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:71:28: note: in expansion of macro 'CAL_APD'
#define CAL_APPEND(a, b) CAL_APD(a, b)
\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:51:25: note: in expansion of macro 'CAL_APPEND'
#define MX_PWM_TRIS_X CAL_APPEND(MX_PWM_TRIS_, MX_PWM_NUM)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:81:38: note: in expansion of macro 'MX_PWM_TRIS_X'
C:\Users\ralph\DOCUME~1\PICFLO~1\PicMZ test 1.c:172:23: error: 'PORT' undeclared (first use in this function)
#define MX_PWM_PORT_1 PORT
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:70:26: note: in expansion of macro 'MX_PWM_PORT_1'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:50:25: note: in expansion of macro 'CAL_APPEND'
#define MX_PWM_PORT_X CAL_APPEND(MX_PWM_PORT_, MX_PWM_NUM)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:81:23: note: in expansion of macro 'MX_PWM_PORT_X'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c: In function 'FC_CAL_PWM_Disable_1':
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\internals.c:305:35: note: in definition of macro 'set_bit'
#define set_bit(var,bitno) var |= (1 << bitno)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:111:3: note: in expansion of macro 'FC_CAL_Bit_In_DDR'
FC_CAL_Bit_In_DDR (MX_PWM_PORT_X, MX_PWM_TRIS_X, MX_PWM_PIN_X); //PWM pin is an input
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:51:25: note: in expansion of macro 'CAL_APPEND'
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC32BIT\PIC32BIT_CAL_PWM.c:111:37: note: in expansion of macro 'MX_PWM_TRIS_X'
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\bin\xc32-gcc.exe reported error code 255
Autoclose turned off
FINISHED
Chad
Re: PIC32 PWM(internal) component broken
Hi Chad
Have you assigned the remap pin connection in the component properties. Same goes for uart based components.
If you have already done this then please post your programs so we can investigate.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Ben,
Unless I make a mistake it seems that it is not possible to do a selection for the remap on the chip in FC
Shouldn't a list open with all the possibility in FC ? if I click on the remap position
at the moment the the list box change to white color with no list or pin descriptions (empty list) :D
Pic 32MZ0512EFE064
chad
Post by chad »
That's what I ran into on a hand full of components that I tried.
Chad
Thanks for letting us know. This one should be fixed now too.
chad
Post by chad »
Thanks, I'll give this another try!
CHad
