IRSensor & LineSensor
For Formula AllCode users to discuss projects, programs, and any other issues related to the Formula AllCode robotics platform.
sundgau
Has thanked: 5 times
Been thanked: 10 times
Post by sundgau »
Hi Benj,
I have two problems with you regarding line and distance sensors.
The first concerns the return variable of the functions "CheckIR" and "CheckLine" which is in byte:
MX_UINT8 FCD_0dcd1_FormulaAllCode1__CheckIR (MX_UINT8 FCL_SENSOR)
while the return variable of "ReadIRSensor" is in full: MX_UINT16 LCD_0dcd1_FormulaAllCode1__ReadIRSensor (MX_UINT8 FCL_CHANNEL)
During operation there are several state changes depending on the distance!
Same for "ReadLine" and "CheckLineSensor".
Another problem now that concerns the simulation; the function "CheckIR" is not simulated unlike the "CheckLine function that works well (and that simulates the first problem).
Thank you in advance for having the time to work on these problems for a V7 flowcode solution!
Bruno
IR-Line_Sensor_Test.fcfx
(15.86 KiB) Downloaded 455 times
Re: IRSensor & LineSensor
Thanks for letting us know. It looks like the bug is present in v7 and v8 so I'll get them both fixed.
Please find attached an updated version of the v7 component. Simly copy the file into your "Flowcode 7\components" folder and restart Flowcode.
FormulaAllCodeP4.fcpx
(335.65 KiB) Downloaded 555 times
sundgau
Post by sundgau »
Sorry but the leds do not work properly anymore ...
Bruno
(6.18 KiB) Downloaded 1337 times
Aha thanks for letting us know, hopefully all fixed now.
(335.64 KiB) Downloaded 499 times
sundgau
Post by sundgau »
Everything seems to work perfectly. Thanks again
Bruno
