Compile error
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Compile error
Post by nnnnff »
why? help me
Flowcode1.fcfx
Compile error
(6.51 KiB) Downloaded 332 times
Has thanked: 1135 times
Been thanked: 299 times
Re: Compile error
Post by jgu1 »
Wish I could help you, but this is over my "limit". :roll:
By the way, have you seen here: viewtopic.php?f=76&t=21735 Concerning the "Icetap"
Edit. **********sorry, my mistake, thought it was someone else. Forget my comment please ************.
Br Jorgen.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Compile error
Post by QMESAR »
Hi.
If you have problems and need help the least you can do is take the time to explain your problem and also tell people what FC version you are using
saying this is not much of help
why? help me
It also shows disrepect to the people you are asking help from,if you do not take the time to explain your problem why should we waste our time to try and assume your problem :)
assuming you are trying to use this code syntax in FC7 or 8, I can say that it will never compile the syntax is totally wrong XC8 compiler used in FC7/8
Search this forum for posts XC8 syntax there are a few from Martin (Medelec ) myself and Ben regarding the XC8 compiler Syntax and regsiter/bit field nameing conventions
