on a pc, the conversion of STEP file to mesh works well but the converter does not launch on the second PC and the result is an image without link ...
I tried to inhibit the anti-virus, reinstall flowcode but nothing helps!
An idea?
thank you in advance
Bruno
PS: On both PCs:
Windows 10 (1909) and flowcode version 7.3.0.7
Model 3D STEP to Mesh
Re: Model 3D STEP to Mesh
Hi Bruno,
I believe the converter opens a pop up window. Is the pop up window maybe being hidden behind something or off screen?
I still haven't solved this problem. Do you have a suggestion for me? The following popup window does not open and flowcode does not convert 3d files to a "mesh" file, so no link is created in "mesh".
I can, however, upload a mesh file created with another PC! I don't have or no longer have this window. I tested all the solutions: uninstall, clean up registry, installation in administrator mode, execution in administrator mode ... All the other functionalities of fc work well An idea?
Bruno
Bruno
- Has thanked: 182 times
- Been thanked: 179 times
Hi Bruno
Check your path from the filename. Sometimes letter like "äöüé" from swiss-german give this problems.
or
There is a trial software for 90 day's you can use for convert, test, remesh, from all format to all format....
https://www.rhino3d.com/de/download
or
