Problem in the round(x) Function
RABO2320
Has thanked: 1 time
Been thanked: 2 times
Post by RABO2320 »
I've encountered a problem with the round (x) function.
The function after compiling on the chip does not work properly on the negative part of the numbers.
This bug exists in both AVR and PIC compilers.
Examples of both AVR and PIC (with Proteus file):
Pic.rar
(25.45 KiB) Downloaded 287 times
Avr.rar
(19.76 KiB) Downloaded 244 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Problem in the round(x) Function
Post by kersing »
Please describe what your results are and what you expect to see.
― C.S. Lewis
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Results obtained:
round(-0.5) = 0
or
round(-1) = 0
or
round(-1.3) = 0
and
round(-1.7) = -1
These results are wrong on the chip but in Flowcode the results are correct
RABO2320
Has thanked: 1 time
Mistake in the round(x) Function
Post by RABO2320 »
Results obtained:
round(-0.5) = 0
or
round(-1) = 0
or
round(-1.3) = 0
and
round(-1.7) = -1
These results are wrong on the chip but in Flowcode the results are correct.
Pic.rar
(25.45 KiB) Downloaded 234 times
Avr.rar
(19.76 KiB) Downloaded 233 times
RABO2320
Has thanked: 1 time
Post by RABO2320 »
No one to answer?
Has thanked: 481 times
Been thanked: 699 times
What is your expected result?
Looks like we simply add 0.5 (effectively rounding to nearest integer, for positive numbers at least.
Do you want rounding up, down, or towards zero?
If you have a project that expects a particular outcome you might need to create your own macro/function to do this.
Yes it looks like we round up.
2.0 = 2
1.5 = 2
1.0 = 1
0.5 = 1
0.0 = 0
-0.5 = 0
-1.0 = 0
-1.5 = 1
-2.0 = 1
-2.5 = 2
Here is the code.
#define flt_round(f) ((long)((f) + 0.5))
Maybe the Floor function would do more as you expect?
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Hi benj
The round (x) function must be the result of negative numbers such as positive numbers:
for example:
1.5 = 2
1.0 = 1
0.5 = 1
0.0 = 0
-0.5 = -1
-1.0 = -1
-1.5 = -2
-2.0 = -2
-2.5 = -3
But the floor function:
1.2 = 1
1.5 = 1
1.8 = 1
0.5 = 0
0.0 = 0
-0.5 = 0
-1.0 = -1
-1.5 = -1
-1.8 = -1
-2.5 = -2
The Flowcode works correctly but does not work on the chip after compiling :!: .
This problem should now be fixed with the latest updates. Help -> Check for updates.
