INTERNAL EEPROM
Genilsonsa
Has thanked: 12 times
Been thanked: 18 times
INTERNAL EEPROM
Post by Genilsonsa »
hello to everyone I would like to use the internal Eeprom of the chip with flowcode 6, I write very well at address 0 with the value 10, but when I restart the Chip I always read it starting at 0. Can someone please help me ?? I remember having already done a project with Flowcode 5 using the internal memory and it worked very well.
EEPROM.fcfx
(9.53 KiB) Downloaded 480 times
Re: INTERNAL EEPROM
The EEPROM component initialiser property sets the initial value of address 0 to 0. Your EEVal count value is also initialised to 0.
Hope this helps.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Re: INTERNAL EEPROM
Post by AbhijitR »
Hello!
In my opinion you should delete the existing data (0,1,0x2,0x03,'A','b',"Hello") from the EEPROM-->Properties-->Initial Values.
And I notice you read "dado" and also display the same on the screen on second line, I think if you want to see the last value saved in the EEPROM then instead of "dado" you should call "EEVal" and show the same.
I hope I understood your point.
Abhi
Genilsonsa
Re: INTERNAL EEPROM
Resolved, AbhijitR and Benj thanks for helping me. Thankful and no more.
