PIC 32MX150 and 24FJ64GB002 SPI Slave Error
Pascal_2016
Been thanked: 4 times
Post by Pascal_2016 »
I try to run the 32MX150 and the 24FJ64GB002 as "SPI Slave".
Unfortunately I get the following error message during build.
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat "SPI_Slave_Error" "D:\PR6751~1\" "24FJ64GB002"
D:\PR6751~1>xc16-gcc -c -mcpu="24FJ64GB002" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "SPI_Slave_Error".c -o "SPI_Slave_Error".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:1062:0,
from SPI_Slave_Error.c:570:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/PIC16BIT\PIC16BIT_CAL_SPI.c: In function 'FC_CAL_SPI_Slave_Init_1':
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/PIC16BIT\PIC16BIT_CAL_SPI.c:698:2: error: 'tris' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/PIC16BIT\PIC16BIT_CAL_SPI.c:698:2: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/PIC16BIT\PIC16BIT_CAL_SPI.c: In function 'FC_CAL_SPI_Slave_Uninit_1':
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/PIC16BIT\PIC16BIT_CAL_SPI.c:871:2: error: 'tris' undeclared (first use in this function)
SPI_Slave_Error.c: In function 'FCD_01531_cal_spi__Prv_SimShowWaveform':
SPI_Slave_Error.c:681:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
SPI_Slave_Error.c:681:6: error: 'SET_PORT_MASK' undeclared (first use in this function)
SPI_Slave_Error.c:736:31: error: macro "SET_PORT_MASK" requires 3 arguments, but only 2 given
Error returned from [xc16-gcc.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat Hat den Fehlercode 1 gemeldet
Can someone tell me what I did wrong
SPI_Slave_Error.c
(49.34 KiB) Downloaded 185 times
Re: PIC 32MX150 and 24FJ64GB002 SPI Slave Error
Please can you post your .fcfx Flowcode project file.
From the C file it looks like maybe the pin connection for the SCK pin is not assigned.
Pascal_2016
the right file
SPI_Slave_Error.fcfx
(10.78 KiB) Downloaded 190 times
In the properties for the SPI_Slave1 component the CLK remap pin property is blank. Assign a pin and hopefully it will start compiling correctly for you.
Your program will likely also need modification as it's not using the SPI slave interrupt etc to get the data from the master. See here for an example.
https://www.flowcode.co.uk/wiki/index.ph ... Interface)
Pascal_2016
Hi, Benj,
thank you for your extensive help
