Possible probem..checked it a few times and different ICs.
FC v8.2.2.15
Working with PIC 18F2580, small test program using i2C (attached), program works fine using software mode, no output on hardware pins in 'channel 1' mode.
Both modes using pins C4 SDA and C3 SCL. All other settings kept the same, just changing the channel type.
thanks, J.
18F2580 I2C Hardware Channel1 not responding
Re: 18F2580 I2C Hardware Channel1 not responding
I can't see the I2C Initialise function being called anywhere in the code? Could this be the cause of the problem? The software channel can probably get away without being initialised.
