Sorry if this has been asked before.
On FC 7 I was able to program the Arduino via the ICSP using the USBtiny programmer, just had to alter a couple of lines as in the attached files.
Is it possible with FC8? It all seems different.
I can't pretend I knew what I was doing but it seed to work fine.
USBtiny and FC8
USBtiny and FC8
- avrc_usbtiny.bat
- (1.5 KiB) Downloaded 157 times
- Arduino Mega 2560 R3 usbtiny.fcdx
- (26.89 KiB) Downloaded 156 times
Re: USBtiny and FC8
Yes it will work the same way, the only difference with v8 is that the compiler toochains are installed seperatley but there is still a batch folder in the batch folder to program via the usbtiny.
Another change is that the Arduino device fcdx files now live here.
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARD
Create a copy of the Arduino Mega and then make the relevant changes to the copied file to get the latest changes and paths etc.
Re: USBtiny and FC8
Thanks, it worked fine.
- (29.54 KiB) Downloaded 153 times
