Circular Buffer
mnf
Has thanked: 70 times
Been thanked: 440 times
Circular Buffer
Post by mnf »
Mentioned this briefly in passing in the forum.
Circular buffer GetNumberOfBytes - doesn't return correct value.
circular_buffer_bug.fcfx
(9.04 KiB) Downloaded 197 times
Demonstrates (in simulation or on hardware) - the circular buffer size (in my demo) is 128 bytes - but the maximum size returned by GetNumberOfBytes is 127.
I think the error is in GetNumberofBytes:
    if (FCV_01211_CircularBuffer1__DATAEND > FCV_01211_CircularBuffer1__DATASTART)
        // .Return = DataEnd - DataStart
        FCR_RETVAL = FCV_01211_CircularBuffer1__DATAEND - FCV_01211_CircularBuffer1__DATASTART;
Following PutByte - DATAEND has a maximum value (the index into the buffer) or 127 - and if DATASTART = 0 (buffer full for the first time) - then the maximum value returned will be 127. This, however, is the index of the final byte rather than the number of bytes. I didn't attempt the math for other possibilities but the value should be +1 here.
PutBytes - looks correct (FCL_TEMP >=128) so reading data from the buffer will possibly lose a byte????
mnf
Re: Circular Buffer
Post by mnf »
I found an excellent article on this at https://embedjournal.com/implementing-c ... mbedded-c/
Having the maximum length of data as one byte less than the buffer size is a reasonable trade off against code complexity - and possibly the easiest way to maintain sanity is to allocate a buffer of required size+1 bytes..
Re: Circular Buffer
Hi Martin,
Maintaining sanity is a good thing :D
At the moment totally filling the buffer would be the same as having an empty buffer in terms of the pointers we use to track things. We could have an additional count variable to track the number of entries in the buffer. I could potentially make this an optional property so you can switch between -1 and totally full.
I don't think we're currently loosing any data but if you find any problems regarding this then please let us know.
