External interupts not working
I am working with the PIC18F45Q10 Micro.
Using External Interrupts INT0 and INT1
The data sheet shows that these are Remappable pins to any PortA or PortB location.
I don't see anywhere to select the pins so I am using the default locations RB0 and RB1 and have an active High switch connected to each.
Flowcode (V8.2.2.15) seems to recognize this setup and simulates correctly.
I compile to Hex (no errors) and program with PicKit3 (attached to EB006V9) with no problems.
When running the hardware the chip does not vector to the interrupt macro when the external switches are engaged.
Hardware is EB006V9 and EB083 I/O brd.
Any thoughts would be appreciated.
Thanks,
Dave
Thanks,
Dave
Re: External interupts not working
Hi Dave,
I have moved your topic to the bugs section as I agree there are issues with the interrupt.
For the selection of INT0 remapable pins, I have temporarily attempted to fix it.
Not sure if will work correctly in hardware or not as not an expert with Fcdx files.
Can you place the attached file in C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC folder.
The folder is hidden by default.
Reload Flowchart and hopefully you will be able to select different pins?
Not addressed IOC.
Not addressed IOC.
- 18F45Q10.fcdx
- (42.89 KiB) Downloaded 231 times
OK nps.
If not working, can you please make sure1 second flash test is working OK?
Hi Dave,
Your welcome.
Try this unofficial fix.
Your welcome.
That is good news.dz28 wrote:Good news INT0 seems to now work!!
- 18F45Q10.fcdx
- (45.51 KiB) Downloaded 226 times
I had a chance to play with this a bit now.
INT0 seems to work OK by itself.
INT1 by itself or along with INT0 is very erratic.
Sometimes triggering sometimes not.
If I add a tMR0 interrupt to the mix things get worst.
I think there is more going on here.
Let me know if you want me to try anything specific to help debug this.
Thanks,
Dave
Thanks,
Dave
Hi Dave,
Is the signal going to the INT1 pin at full VCC and VSS voltage? Also is the rise/fall time nice and fast, we have seen unexpected things when using capacative type signals.
H Martin,
Thanks for the fix to the FCD. I've checked the datasheet and your solution looks good to me so I've applied this fix to the rest of the family.
H Martin,
The signals look good.
I am using Eblocks boards EB083 and EB006V9
Programming with PicKit3 plugged into the EB006V9
The Switch signals do fall short of 5V only swinging to 3.1V at the PIC
EB083 is unmodified.
Weird thing is that if I write a program to toogle an LED every 1 sec in the TMR0 interupt routine everything works fine.
If I add INT0 and a switch on RB0. The LED flashing becomes erratic. This happens with the INT0 switch untouched and RB0 sitting at Ground.
I will mod the EB083 board so it switches to 5V.
Dave
Dave
Can you post a flowchart that has the issues you have described?
Martin,
Attached are 2 flowcharts
Both simulate fine in flowcode.
"Test2" seems to work fine programmed to hardware.
"LED_Flash" adds some minor complexity to the interrupt routines and main loop.
The TMR0 led flash struggles to stay in sync when programmed to hardware.
Could be some type of programming error that causes a conflict on the portA outputs?
Thanks,
Dave
Thanks,
Dave
- Test2.fcfx
- (14.04 KiB) Downloaded 214 times
- LED_Flash.fcfx
- (19.16 KiB) Downloaded 204 times
Not sure if will make a difference or not.
Can you try with a basic port output instead of Led_5mm turn on/off?
Ahh, that's good.dz28 wrote:Moved the TMR0 LED to PORTB and it seems happy now.
I did suspect that the same component within different interrupts could cause an adverse affect.
Just was not 100% sure where LED components are concerned.
Glad its now working as expected.
