Save Tab arrangement?
Xbeejunior
Has thanked: 9 times
Been thanked: 3 times
Post by Xbeejunior »
you can arrange tabs (macros) differently and also display several at the same time in the program, is it possible to save your own arrangement, just as you can do with the window arrangement?
Re: Save Tab arrangement?
I don't think it's possibe to save the order of the tabs, though the current tabs that are open will be saved.
If you drag one of the tabs to the right hand side then you can have two flowchart windows open side by side at the same time.
It's also possible to undock the flowchart window by dragging the tab and have multiple floating windows. This might be able to be saved as a window layout but I haven't tried this.
Xbeejunior
Hi Benj,
unfortunately none of this is possible, I didn´t get it .....
Thanks for the suggestion - I'll add it to our development list and it should hopefully find itself in a future release of Flowcode.
