T6963C Display Driver Support
edward
Post by edward »
Hi guys
I have problem with refreshing display rates turns slower when using font size more than 13 and even slower when more larger size , I think FLOW CODE use micro controller ram for sending fonts (If i guess right) . Is there any register selection in LCD macro or way to select LCD RAM or MICRO RAM in the FLOW CODE 8 to download fonts in LCD RAM while initializing or something else to do this and increase refresh rate in large fonts.i cant find it . may be I`m in wrong.
micro: ATMEGA2561
display: LCD 240*128 t6963c TOSHIBA.
thanks for your help :)
Re: T6963C Display Driver Support
As you mentioned v8 I have moved your post from the v6 section.
It will make it easier to get help, if you uploaded flowchart you are having an issue with.
edward
Post by edward »
T6963C V METER 2561.fcfx
(10.8 KiB) Downloaded 270 times
No way to store things in the display ram as far as I am aware.
Can you clock your ATMEGA faster, currently it's configured for 8MHz but I believe it will run up to 20MHz. This should make a big difference.
Also as you are using a port for the data pins the GLCD component property "Data Uses Port" will give you a big speed boost if you set it to Yes.
edward
Post by edward »
Atmega2561 allows max 16 MHz clock frequency .
by tomorrow i`ll change crystal to 24 MHz to see whats happening .
I changed $PORT A to YES state and refresh speed got better. :D
thanks
edward
Post by edward »
Hi again.
maybe a stupid question but how it`s possible to print long format number on t6963 or ssd1305 displays cause in macro just allow to print max 32768 ?
Should I divide in in two parts less than and greater than with printing with $left and $right separately or there is better way?
I want to print raw ADC output of hx711 in those displays.
thanks.
Hi Ed,
You can print Long, Ulong etc by adding a string variable.
Using the ToString$ function, then sending string to your gLCD.
I have attached an example flowchart
Print Long.fcfx
(8.35 KiB) Downloaded 233 times
