GPS - Using Mikroe BL0106 Click Adaptor
gavo4
Been thanked: 8 times
Post by gavo4 »
Hi All,
I am a newbie to the Flowcode and I tried the Standard GPS Test Program which I modified for the Arm Development kit BL0061-1 and can't seem to get it to work at all.
I also used the RS232/UART Component and tried to receive one character at a time with no success.
Please see attached, can anyone perhaps point me in the right direction please?....;-)
Gavin
ARM_DEV_GPS.fcfx
(16.89 KiB) Downloaded 184 times
gavo4
Re: GPS - Using Mikroe BL0106 Click Adaptor
Post by gavo4 »
Oops meant to add I am trying it with the GNSS Click 5 and the GPS3 Click board as well
Has thanked: 182 times
Been thanked: 179 times
Hi Gavo
Can you post a foto from your hardware?
Do you have a drawing or wiring list to the clickboard?
Pin 2 from the Clickboard is reset => set it to hi
Pin 13 RX to Arm TX
PIN 14 TX to Arm RX
gavo4
Post by gavo4 »
Hi Stefan,
Look at the Consol as well when I simulate it does something very weird.
When I run the GPS Injector in the Simulation is seems to work
How would I pull the reset pin high?
Gavin
Hi Gavin
I do this with a "virtual" LED.
From the component output I get a LED (5mm, Panel).
Then I give this LED a name and determine the port in the propertis. If you use the the clickboard on connector D, in your case it would be maybe D7.
You can set the pin with a component macro to TurnOn. For a reset you can use the component macro and set the pin to TurnOff for a short time. The reset pin is active with a low.
18-08-2020 10-33-03.png (140.41 KiB) Viewed 2210 times
