New RTC Component Macro
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I was programming with this component.I wanted to get Minute,Hour, Date and some others. See the images uploaded.
Within the dialog, I was able to assign the Minute and Hour to a variable. But for the Month,Date,and Year, there was not the option.
I am only showing the error/picture for the Date.
Thanks in advance.
Get Hour.png (188.27 KiB) Viewed 3395 times
Get Date.png (187.77 KiB) Viewed 3395 times
Re: New RTC Component Macro
Hi billduck,
The parameters is an input that's used if you have different functions that can be returned.
Just hover mouse below the Name or Type to see different return option values available:
In your case the Expression needs to be 0, since you want the normal clock hours & not any of the alarms assigned to your variable.
The Return value will be the variable you assigned for the function. e.g Hour.
Where there are not any parameters to enter, the component will only return the function name i.e in this case the Date:
I have moved the topic from bug reports, since not a bug.
billduck
Post by billduck »
Thanks. I think I was asleep at the wheel. And will study and learn this.
billduck
Variable arrays
Post by billduck »
Hey medelec35 - I am looking for a tutorial on using arrays.
Any help is appreciated.
There is a small section on arrays here that might be of use.
https://www.flowcode.co.uk/wiki/index.ph ... _Variables
