Looking for .FCD for PIC16LF15313
Bep
Been thanked: 2 times
Post by Bep »
Hi. Getting the "...the definition file PIC..16LF15313 is missing or corrupt" error when I create a new project.
I have not been in the program for several months. I can't seem to remember how to update these files if they are available.
My "check for updates" is not highlighted. Present installed version is v8.1.1.11.
Thanks,
B
Re: Looking for .FCD for PIC16LF15313
Bep wrote:
Mon Sep 28, 2020 7:51 pm
It's not highlighted because your version is out of date.
You should be on at the time of posting v8.2.2.15
You will need to go here
Select the I'm not a Robot.
First download and install the patch.
Then finally download and install the hotfix
Finally Use Help, Check for updates.
Bep
Post by Bep »
That solved it!
Thanks,
B.
Hi B,
Glad issue is solved for you.
Thanks for letting us know.
