Integrating PicKit3 into FC8, Guide?
beneee
Has thanked: 6 times
Post by beneee »
Hi all,
Is there a step by step on how to integrate a PicKit3 unit into FC8 and m-blocks2 so I can program chips not supported by mloader and still have the convenience of my code running (or not) imminently and not having to swap chips around or unplug things.
I have installed MPLab 5.4 but don't really know where to start in connecting it to Flowcode so it works seamlessly.
Thanks for your help
Ben
Re: Integrating PicKit3 into FC8, Guide?
Hopefully this page should help get you up and running.
https://www.matrixtsl.com/wiki/index.ph ... ming_Tools
beneee
Post by beneee »
Thank you Benj, all up and working now with my "hi-tech" programmer, is the issue of the chip I am using 12F1501 not being included in mloader an intentional choice due to compatibility and is it likely to be added in the future?
Is it possible to add the chip manually?
Ben
