STM32F042 Nucleo!
Has thanked: 1135 times
Been thanked: 299 times
STM32F042 Nucleo!
Post by jgu1 »
Hi!
Help needed. Please look in the config for my testprogram, is the speed as fast as possible? I want to use this device for a ILI934 display, so fast update on the display. There are lot of settings in the config :roll:
Thank's in advance.
Br Jorgen
STM32F042 NUCLEOtest.fcfx
(6.47 KiB) Downloaded 191 times
Alkaline
Has thanked: 42 times
Been thanked: 41 times
Re: STM32F042 Nucleo!
Post by Alkaline »
HI
in attachment you will find the version with the clock set at 48 mhz
I don't have the card to test but it should go.
Furthermore, if the speed was still not sufficient I solved it by changing the clock source from internal (HSI) to external (HSE)
I use the external 32 MHz HSE clock
You can get a further increase in performance by changing a compiler parameter, but we will discuss this after the tests.
I am also attaching the link from which you can download the excel sheet you stm from which you can obtain the clock parameters
https://www.st.com/en/development-tools ... 32088.html
STM32F042 NUCLEOtest_48Mhz.fcfx
(6.47 KiB) Downloaded 188 times
Post by jgu1 »
Hi Alkaline!
Thank you very much.
Br Jorgen
