Fast display ST7789!
- Has thanked: 1135 times
- Been thanked: 299 times
Seemed to be a nice fast color display. And cheap. Is it hard/difficult to add FC8?
Look here: https://www.youtube.com/watch?v=-nECx4DOE84
Br Jorgen
Br Jorgen
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: Fast display ST7789!
First contact..
Connected up to a Nano - and Adafruit library didn't work at all. (I'm sure it did previously but on a Mega - so maybe a memory issue?)
So tried the https://github.com/cbm80amiga/Arduino_ST7789_Fast library - and after a little fiddling - an Amiga ball sprung onto the screen (for retro fans)
Using a level shifter - D13 to SCL, D11 to SDA, D8 to RES, D7 to DC, 3.3v to VCC and GND (of course) BLK can be left floating or pulled to ground for off (note if pulled high pull to 3.3V not 5V)
Neat little display!!
As an aside - this would be a cool project to try with Ben's interface board??
Hi All!
Sound¨s good Martin. Hopefully MM guy´s will accept your offer and create a component macro for this display. As soon we know, I will order a couble. ( can use it for my Wireless rs232
Br Jorgen
Br Jorgen
mnf
I was thinking a community effort would be good here
But, made a start. Initialisation set up yesterday evening today hopefully will get something 'displayed' even if it's just changing the screen colour!
Will need some testing too!
Ok Matin, Nice.
Try to look here, rally full speed
https://www.youtube.com/watch?v=OOvzmHcou4E
Jorgen
Jorgen
Mine are still on the slow boat. That full speed test looks great! ALL of the graphics FC drivers are slooow. I am using a 64x128 i2c black and white oled for testing now and it is slow. I tried it on an Arduino and it is many times faster. I am running it on a 64mhz chip and have the i2c cranked to 1mhz.
Ben was working on a new graphics display a while ago. Don't know what happened to that.
Chad
Chad
Hi All,
I've had a quick go at creating a component for this display.
Here you can find the built component, you need to copy this file into your "C:\ProgramData\MatrixTSL\FlowcodeV8\Components" folder.
The folder is hidden by default so simply paste the address into the address of your file explorer.
Let me know how you get on, if it works ok then I'll post it via the update system.
Here is the library that I based the code on.
https://github.com/ananevilya/Arduino-ST7789-Library
Also here is the component source project which might be useful if there are any problems or if you want to have a crack at supporting other displays.
Which display are you using Chad, maybe we can have a look and speed it up for you.ALL of the graphics FC drivers are slooow. I am using a 64x128 i2c black and white oled for testing now and it is slow. I tried it on an Arduino and it is many times faster.
Wow Ben, Thank´s. I will immediately order some at Ebay. Hopefully Martin (Mnf) wil test, he have one.
Again thank´s.
jorgen
Again thank´s.
jorgen
mnf
Doesn't immediately work on a Nano...
Display clears so looks like initialisation is occurring but Print ("Hello World" of course) did nothing - nor did changing the foreground colour and clearing the display..
Ok thanks, What about changing the BG colour and clearing the dispay?
Also have you tried changing the toggle CS Pin property to Yes to see if this makes any difference?
Maybe also try printing at a few different coordinates? I've already done a comp for this display in v9 and it has a big offset to the viewable area. Though you would probably see this with the clear function not clearing all the visible area.
mnf
Hi Ben,
Yes - tried that - and no joy. CS set to D10 and tried with and without (board has no CS) (but SPI likes it to be D10?)
Changing colours in properties (FG or BG) makes no difference either (though works correctly in the sim)
Thanks Martin,
Hopefully the attached will make a difference
I think this is now more in line with working v9 component code so fingers crossed.
mnf
Still no lights... I've got some more time to work with this next week - so I'll see if I can spot anything. Note that the Adafruit library doesn't work with the display I have but the 'fast' library mentioned above does - so it might be a subtle initialisation difference?
Hi Ben and Martin!
Something new concerning the display (kindly). I expect to receive my display soon, look forward to test.
Thank´s in advance.
Br jorgen
Thank´s in advance.
Br jorgen
Hi Martin!
I see today that the display is add in the update, so maybe Ben (thank´s) have made some correction.
Unfortunately I have still not received my display. I know you have one, maybe you will test
I also create a testprogram while I wait I look forward to test.
Br Jorgen.
Br Jorgen.
- St7789Test.fcfx
- (11.3 KiB) Downloaded 603 times
- st7789.PNG (10.22 KiB) Viewed 114209 times
I've now added the reset pin, made the CS pin optional and tried to follow the exact sequence from the Fast library.
Fingers crossed.
Fingers crossed.
Hi Ben!
Thank´for update. I just made update from helpmeny and then made a testprogram with an Uno. But sorry not working.
Do I have to use the above FCPX file? Is it the same as in updatE? Edit, Well none of them work...
(Have keep my finger crossed
Br Jorgee
Br Jorgee
- First test.fcfx
- (8.26 KiB) Downloaded 665 times
Hi Jorgen,
What about trying to toggle Backlight on and off, could be defaulting to off?
Any reaction on the dispay at all?
Yes the version on the update system is the same as the version here.
Hi Ben!
Yes toggle backligth working. The only thing I can see is, If I first have programmed with Arduino IDE a testprogram, and then program with FC the screen is getting black, nothing else, well the bagligth toggle work.
I can send you a display if ok, I imagine it is easyer to get it working if you have one to do test. You can keep it jump on it or throw it away, but first when it work
Let me hear.
Jorgen
Jorgen
- First testLedToggle.fcfx
- (8.95 KiB) Downloaded 553 times
