Fixed frequency timed output
siliconchip
- Has thanked: 101 times
- Been thanked: 25 times
Hi all, is it possible to generate a fixed 60Hz square wave for a timed period from a pic and if so how should i start to approach this, thanks in advance
Bob
Bob
- Has thanked: 182 times
- Been thanked: 179 times
Re: Fixed frequency timed output
Hi Bob
There is a very praktikel tool in flowcode to generate a signal
https://www.flowcode.co.uk/wiki/index.p ... ator_(DSP)
or if you need a signal on a pin you can use an interrupt for this.
If you explain more we, can help you more....
siliconchip
Thanks stefan and martin this gives me something to get started on
Cheers
Bob
Cheers
Bob
siliconchip
Hi ive added my code without testing on hardware at this point im hopeful ive got the correct calculations for 60Hz, also is it acceptable the way i start the toggle then disable the Interrupt after 20 seconds or is there a better way
Cheers
Bob
Cheers
Bob
- 60Hztimer.fcfx
- (11.26 KiB) Downloaded 387 times
Hi Bob,
Nothing wrong with your flowchart from what I can see.
I have attached an alternative flowchart which is the way I would do it.
The timer interrupt fires way too quickly during simulation only.
For that reason, I have used the IsSim component, which is used for calling the interrupt macro during simulation.
Also is using the delay component they are not as accurate as timer interrupts and the delay will not allow you to run anything else until it has finished.
For that reason I have used the interrupt for the delay.
- 60Hztimer Alternative.fcfx
- (13.18 KiB) Downloaded 413 times
siliconchip
Hi Martin thanks as always, I've been messing around also to try and display the output frequency but I'm running into walls everywhere is it even possible ??
Bob
Bob
Hi Bob you're welcome.
Unfortunately, the built in scope and data recorder is not accurate for simulations.
The only way I can think of is use a third part simulator that loads hex files or for 8 bit pics use - BL0011 - 8-Bit PIC Programmer.
As you can use ICD.
That will make the built-in scope and data recorder be 100% accurate.
Also you can see the variable values of hardware.
As the physical pin is toggling, you can use test equipment like a scope or analyser to determine frequency.
You could also place microcontroller on a solderless breadboard and program via ICSP.
As you can use ICD.
siliconchip
Do you mean just show 60 Hz on the display for the 20 second duration and 0 Hz when not generating a 60 Hz frequency?
siliconchip
Hi Martin yep spot on when it runs for 20 secs show it's output on the lcd I did try but didn't understand how to convert the toggle
Bob
Bob
This should do that.
- 60Hztimer Alternative 2.fcfx
- (15.59 KiB) Downloaded 412 times
siliconchip
Martin thanks I can't check it at the moment but I'm sure as always it's awesome I will provide feedback tomorrow now where's that bloody thanks button
, once again top bloke thank you
Bob
Bob
Haha, Thanks Bob
You are welcome.
Lets hope it's what you are after.
Don't forget to test speed on your hardware as a first step, buy doing a 1 second flash test.
I hope the thanks is brought back soon!
You are welcome.
Hi Bob,
Sorry false of habit using V8.
IsSim was introduced in V8.
I have posted a V7 version with the Sim detection events added, so will work the same.
When running simulation the interrupt will be ignored and the Call Timer2 macro will be accessed.
The opposite will be true when running on hardware.
- 60Hztimer Alternative 3.fcfx
- (17.49 KiB) Downloaded 337 times
siliconchip
Hi martin this would explain the issues i had trying to simulate once i did i noticed that when button was pressed instead of running for 20 seconds it ran for about 0.5 of a second, where as this runs alot longer, should this then in hardware run for approx 20 secs ? I realise hardware testing is the end goal but work is not permitting this yet
Edit just timed this and still runs continuously after 2.5 mins in simulation hence does this relate to your comments above about software and hardware
Bob
Bob
Yes that's simulation only.siliconchip wrote: ↑Sat Oct 24, 2020 12:50 pmi did i noticed that when button was pressed instead of running for 20 seconds it ran for about 0.5 of a second
On hardware, the interrupt will work at the correct frequency, so the delay will be at 20 seconds.
The attached flowchart misses out the interrupt during simulation, so will take care of that.
The delay will still not be same as hardware but will allow you to single step so you can follow whats going on.
siliconchip
Hi martin
That makes sense with my interupt calcs the ouput should be 60Hz in hardware, ?? Should this 60Hz sway in the real world ie drop down to 58 this wouldnt show on the display would it or is it such that timing remains stable i would be using INTOSC at 16 MHz
Bob
Bob
Yes, the interrupt service routine will be accessed 120 times a second.
As pin A0 changes state every time interrupt is accessed, then the pin frequency will be 60Hz in hardware.
Yes, it will remain stable at 60Hz for the duration of the 20 seconds, even if using internal osc.
The LCD just prints a string that is "0" or "60" then "Hz".
Flowchart does not measure frequency.
siliconchip
Hi martin thats great as i said i need to test in hardware and ive started to adapt it further but thank you for putting the time in its appreciated and hopefully now the use of interupts rather than delays will be a new avenue for me in future, your a top bloke and Matrix take note lol
Regards bob
Regards bob
siliconchip
hi all
ive started to adapt the above flowcode and im trying to display the actual toggle output of the port and dividing the value by 2, which should be 61Hz but the output changes every second i can briefly show the output but its constantly resetting any ideas how i could capture or sample this, also when running on proteus software im getting stack underflow ???
cheers bob
cheers bob
- 60Hzfreq.fcfx
- (18.74 KiB) Downloaded 339 times
siliconchip
hi martin
thanks as always for the input, i rearranged as per your pic but no change on display, i then moved freq=timertick/2 from the calc box you showed because this was with TimerTick =0 to the calc box above the decision but i got similar results before, the hertz counts to 60 but after 120 counts resets again
bob
bob
- 60Hzfreq.fcfx
- (18.83 KiB) Downloaded 342 times
The idea of the moving the calculation within the interrupt was so the 60 is shown only when LED is enabled and output is on (and see seconds counting).
Otherwise displays shows as 0.
Just tried it and works every time for me.
Changed your flowchart to replicate the image I have posted.
I can see a solid 60 for 20 seconds
Is that not what you want?
I would also recommend tiding the display up.
E.g have:
Freq Time
60Hz 15sec
After the c you will need to add a space otherwise toy will see with seconds less than 10 the word secc
instead of sec
E.g have:
Freq Time
60Hz 15sec
instead of sec
- 60Hzfreq v2.fcfx
- (19.06 KiB) Downloaded 386 times
siliconchip
hi martin
i copied the reworked timer as per your first comment but it didnt work ?? if i went wrong not sure where it was V2 is working in flowcode but when i simulate in proteus it gets as far as 3 seconds then error message flags
"[PIC16 CORE] PC=0x04C0. Stack overflow executing CALL instruction. [U1]"
[PIC16 CORE] PC=0x04D5. Stack underflow executing RETURN instruction. [U1]
[PIC16 CORE] PC=0x070F. Stack underflow executing RETFIE instruction. [U1]
and the program fails to go any further, i realise this is not hardware testing just wondered if proteus has picked something else up, also proteus did not flag any faults until i started to try displaying the toggle frequency ??
ive reopened proteus and tried again its behaving at the moment
bob
bob
