7seg4 common cathode
leha_m1986
Hello there! Please tell me, does not change the type of indicator from a common anode to a common cathode. "Custom code - > Defines -> Edit code - > line 37 - > 0=common cathode, 1=common anode" - no result.
- VIMET.rar
- (180.09 KiB) Downloaded 436 times
leha_m1986
Re: 7seg4 common cathode
Redesigned the project in Flowcode 8 . Here, too, the problem, collect voltmeter-ammeter. Individual measurements work, but they don't work together. Tell me where I made a mistake
- metr.rar
- (18.42 KiB) Downloaded 406 times
For the floating point maths to work try changing your constants from 1000 to 1000.0 to force a floating point calculation, or if you can use integer maths instead.
leha_m1986
Hi, but separately everything works! but not together. And I have problems with the dynamic display, the" hardware " indicator flickers strongly, and generally behaves strangely...Can you advise how best to do it?
- Has thanked: 187 times
- Been thanked: 205 times
Have you had a read at these posts?
https://www.flowcode.co.uk/mmforums/view ... 76&t=21119
They should prove quite helpful.
