ST7789 Bug!
Has thanked: 1135 times
Been thanked: 299 times
ST7789 Bug!
Post by jgu1 »
Hello!
I thought there is a little quiet here in the forum, is everyone on vacation :lol: :lol:
Well ok, maybe I can make a wake up :wink:
Now I see that the ST7789 display i s added to the component in FC8 so I suppose it is ok I report a bug. Finally I get my display and I made a test, but as Martin also mentioned here: https://www.flowcode.co.uk/mmforums/view ... 77&t=22377
It doesn´t work. :(
Hopefully MM/Ben have time to have a look .
Br Jorgen
St7789Test.fcfx
(11.29 KiB) Downloaded 317 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: ST7789 Bug!
Post by mnf »
Hi Jorgen,
I think the Adafruit version has a slightly different initialisation...
Sorry - haven't had time to work with this lately, but will get round to it soon(ish) hopefully..
Re: ST7789 Bug!
Post by jgu1 »
Hi Martin!
Ok, No rush. But I like this tiny coloured display. I made a test with the Arduino ide, and it work fine.
Look forward to see it work in FC8.
Thank`s Martin.
Br Jorgen
Re: ST7789 Bug!
Post by jgu1 »
Hi again Martin!
Some more info maybe it can help :D
I have made some reserch on the web and I have downloaded a project from here with a temperature DS18b20: https://www.youtube.com/watch?v=-nECx4DOE84
First I follow his project step by step. Get the lib. and all. Follow his connection, power 3.3V and connect the datapin directly to the output, 5V. Damaged the display, it doesn´t work. I search some more and see different opinions how to connect the datapin. I try with resistor divider, no luck. then I try with only 2k7 resistor in serie only on data pin, then it work and is very nice and stable.
Subsequently I perform test with FC8 again, but :cry: no luck Of course I could use the others projects, but prefer to make my own in FC :D
One more thing, the name of the pin on the display fit, but not on the delete pin on the display, is this in FC8 CHIP SELECT?
Br Jorgen
Re: ST7789 Bug!
I've remade the component with a reset pin on the other topic.
As for the CS pin please assign this to an unused IO pin.
