Ports A6 & A7 not accessible
Hi all
I am setting up another project with the settings based on a previous working setup driving a GLCD. I want to use ports A6 & A7 but they are grayed out as if in use as OSC1 & OSC2, I think I have disabled all usage of the external oscillator functions to release the ports for general use. Hopefully someone looking from a different angle can see where the issue is, the 1 second test is bang on.
Ian
Ian
- new_project.fcfx
- (6.54 KiB) Downloaded 368 times
Re: Ports A6 & A7 not accessible
Hi Ian,
As a temp unofficial fix can you try the attached file?
You will need to place it in C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC which is hidden by default.
If file was added when Flowcode was running then flowchart will require reloading.
- 18LF27J13.fcdx
- (54.82 KiB) Downloaded 316 times
Hi Martin
Thank you for your reply, I have replaced the file and reloaded FC but the ports remain grayed out, would you mind having another look please.
Many thanks Ian
Many thanks Ian
Hi Ian,
Working okay for me: Did it state you already have a file with the same name and do you want to replace the file in the desination?
You are a genius Martin, my mistake was to allow FC to do an update which rolled the file back!
All good now, thank you!
Ian
Ian
Thanks Ian,
Glad you sorted it now.
No problem easily done.
I have not got the chip to test A6 &7.
Hopefully will work okay.
Yes that will do it.
I have moved topic to bug reports for Matrix staff to sort out.
Thanks Martin,
This one should be fully sorted now, found a few devices with the same problem.
