Hi Team,
Can you please advise me on using the dsPIC MIAC RS485 should I add the 120 Ohm terminator resistor or is this already included in the Hardware.
I did not find any reference in the manual regrading the terminators
Appreciate your input
dsPIC MIAC RS485 Communication
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: dsPIC MIAC RS485 Communication
Hi Leigh
Can you also tell me please if there is TVS diodes on the front end of the Transceiver node to protect the transceiver ,as this MIAC will run in an noisy environment.
Thanks a million
Thanks a million
Regards QMESAR
Regards QMESAR
- QMESAR
Leigh
Thanks now I know how to layout the wiring and connections the internal ESD TVS is not enough for sure
Regards QMESAR
Regards QMESAR
