Clock setting
mnf
Has thanked: 70 times
Been thanked: 440 times
Clock setting
Post by mnf »
A visual bug.
Using an ATTiny MCU (I tried 88 and 22 others maybe affected too) - set the clock speed to > max speed (so for I tried 16 and 32MHz) - this (correctly) says 'greater than max speed' - but then displays the 'loading targets' with whirly. This stays until clicking 'cancel' which gets rid of it and no harm done..
Re: Clock setting
Hi Martin,
Thanks for letting us know, that's certainly a strange one. I'll pass this onto Steve so he is aware of it.
Re: Clock setting
Hi Martin,
Thanks for identifying this glitch. I've checked Flowcode v9 and this problem doesn't happen there. I've also identified what's happening in the code for v8, but I'm not going to fix it as it's a minor issue that doesn't cause any other problems.
Steve.
mnf
Re: Clock setting
Post by mnf »
Thanks, yes it didn't seem to cause a problem - and gone in v9...
