In the past i was using PIC18F26K22 and everything was working well in FC8, recently i migrated to PIC18F26K42 for 12bit ADC, only changing the chip in Project Options did not work, there are so many new settings
can someone shed some light on this, thank youC:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_I2C.c: FC_CAL_I2C_Master_Init_1()
266: SSP1DATPPS = 0;
^ (192) undefined identifier "SSP1DATPPS"
269: SSP1CLKPPS = 3;
^ (192) undefined identifier "SSP1CLKPPS"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_I2C.c: FC_CAL_I2C_Slave_Init_1()
661: SSP1DATPPS = 0;
663: SSP1CLKPPS = 3;
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_1()
551: INTCON0bits.PEIE = 1;
^ (255) not a member of the struct/union ""
^ (182) illegal conversion between types
int -> volatile union S2036
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Uninit_1()
908: PIE1bits.RCIE = 0;
int -> volatile union S151
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_UpdateBaud_1()
1564: PIE1bits.RCIE = 1;
1565: INTCON0bits.PEIE = 1;
TLIC_18F26K22_OLED_CI_4R_15-01-2021.c: default_isr()
19387: if ((PIR4bits.TMR3IF) && (PIE4bits.TMR3IE))
(199) logical type required ^
19390: PIR4bits.TMR3IF = 0;
int -> volatile union S188
19403: if ((PIR1bits.RCIF) && (PIE1bits.RCIE))
TLIC_18F26K22_OLED_CI_4R_15-01-2021.c: 19403: too many errors (21)
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
Abhi
